Re: Lake county hybrid pads
Quote:
Originally Posted by
WRAPT C5Z06
I tried the force grey pad with the 3401 and the pad was just way too stiff. Not a good user experience at all. Won't use it again.
Sent from my iPhone using
Autogeekonline mobile app
Good to know.
I think he prefers using a wool pad on the 3401 over the grey pad.
Zubair
The Orange Hybrid and Orange Force use the same foam that does not work well at all in warmer climates.
well dernit. I was hoping that wouldn't be the case
Zubair
Agreed. It's misleading when it says it's a cutting pad, because in warmer temps, it becomes a polishing pad.
WRAPT C5Z06
what would be the go to pad in warmer climates? (just trying to be prepared)
Thenissanguy
Blue Hybrid or Force Grey.
I just picked up most of the BOSS pads and the heavier cut B&S Low-Pros. The white and orange BOSS ones and the green and orange Low-Pros are all very firm/stiff.
Someone said the BOSS pads soften up after use. I've only had the chance to try out the white one on my trunk and it didn't seem to soften up much in the short time I worked it.
The only time it was soft was when I was washing it with hot water afterwards.
WRAPT C5Z06
The B&S Low Pro green and orange pads are some of the best foam pads I've used with the 3401
Yep, use it with the Flex 4 3/8 bp and you won't use the Hybrid system again.
Zubair
So in the summer the blue hybrid and oramge hybrid switch spots on cutting power in the summer?
WRAPT C5Z06
Maybe we can meet up one of thse days so i can pick your brains
