Results 21 to 30 of 40
  1. #21
    Senior Member Todd@RUPES's Avatar
    Dec 2007
    Orlando/Oviedo
    389
    Re: rupes 21 destroyed some good quality pads
    I am sitting on an airplane so I cannot go into too much detail, but your polishing time per section is about 4 minutes too long. After 1 minute you are loading paint residue into the pad, the abrasives are loaded with paint, and the lubricant is no longer as effective.
    The combination of a lubricant that has lost efficiency and a slurry that has more solid content mean your results are going to suffer. You are also inducing more drag at the foam/paint interface which means the pad is flexing more and heating up. The longer you work it, the more the problems increase and internal temperature of the pad goes through the roof.
    Shorten your work times by about 500%. You will getter a better finish, better pad life and you'll be done faster
  2. #22
    Senior Member rlmccarty2000's Avatar
    Dec 2013
    Fitzgerald, GA
    1,047
    What Todd said. Beat me to it. Polish 30 -45 seconds, brush off pad to remove spent product and removed paint, add more product and move to next section. 5 minutes will create way too much heat. Also, it is best to only use Rupes polishes with Rupes pads. Other polishes have solvents that can cause delamination and general pad deterioration.
  3. #23
    Apr 2015
    PGH, PA
    1,229
    prob could do with speed 3.5 too
    but figure like 3 seconds for shoulder to shoulder for polisher movement
    5 pea drops initially
    after 4 section passes..maybe 6 clean pad with brush
    then apply 3 to 4 pea size drops
    repeat till panel is done then move to next with a fresh pad
  4. #24
    Senior Member swanicyouth's Avatar
    Mar 2011
    Limerick, PA
    9,276
    I dunno.
    I'm still using the Rupes pads that first came out when the first machine became available at AGO.
    None have failed.
    Granted, I only use them a few times a year.
  5. #25
    Member
    Aug 2015
    41
    thanks guys for the tips, i will try to reduce my polishing time in order to keep my pads alive (my FLEX 3401 is so different in that sense ...)
    one thing is not really clear to me-if speed 4 is the maximum we have to use with the 21 mark2 and faster is just to wild and destroying pads, why do they offer speed 5-6? curves? why not just add even more Torque to handle the curves ?-that fast motion is just to wiled and not healthy to the pads (especially with the washer MOD) and because no Mather what (mark2 and all the tweaks they add) it's just bad on curves and cant do half of what the flex can do -but that is just another case (-:
  6. #26
    Member
    Aug 2015
    41
    Is the middle yellow pad, a Rupes pad?
    yes-it's the same rupes pad that destroyed a few days after ..
  7. #27
    Aug 2014
    Brazil
    491
    The 21mm throw is hard on pads, even if you use the Chinese Rupes knock offs it will wear out pads fast.
    With the 21mm throw, you have to use Rupes pads or pads designed for it, like LC HD line or B&F Urotecs.
    The 15mm orbit is less forgiving, in case you want to play around with different pads.
  8. #28
    Senior Member dlc95's Avatar
    May 2013
    Rochester Hills, Mi
    4,285
    Quote Originally Posted by aderet View Post
    Thank you.
    A few things come to mind.
    1. Though it's unlikely, check backing plate. Make sure it's gripping the pad securely. If it isn't securely gripping the pads, that itself can get things hot at the surface, resulting in pad blow out.
    2. I did watch the video, and I believe there is still too much pressure being used. Also the pad didn't appear to be flat on the paint. On flat panels, the pad should be flat. The angled pad + consistent pressure load will cause pad destruction as well.
    3. Some after market pads that are taller won't be able to handle the extreme lateral motions found on these tall stroke machines. These taller after market pads twist and flex in the middle, heat up, and blow out.
    The only problem I really had with Rupes pads is that I've had the loop backing die on a couple yellow pads. I was learning how to use the system with them, and used too much pressure. I've also had the blue microfiber fall out due to improper cleaning methods (anyone reading - be gentle with a pad cleaning brush. The fibers are looped - not straight strings. Too aggressive cleaning can have the brush bristles get caught on/in the loop holes, which can end up pulling the fibers out of the substrate... I now brush them lightly, or use and old credit card to scrape them off). That Zephir compound cuts a lot of paint off a vehicle, and the microfiber pads can really get full fast. It's also unique in that the compound is both sticky and dusty if allowed to build up.
  9. #29
    Senior Member Detailing by M's Avatar
    Mar 2013
    Plano Tex-ass
    998
    I've never had a problem like this. It's your technique. Your generating to much heat. work smaller areas and work shorter times.
    I've had my Bigfoot since they came out. Sure a few pads get torn up with use but it's years before that happens. Just normal ware. But never have I destroyed pads like that. I wash my pads right after I use them and I keep them for years.
  10. #30
    Feb 2015
    Ft. Lauderdale,Fl
    491
    More speed more heat= less time to work before you destroy your pads. I switch my pads every few minutes when doing large areas to keep them from overheating. I may have a few more pads to clean at day's end but they are not going in the trash can
  1. Rupes 21 MK II Unboxing (Very High Quality!)
    By RFLCT in forum RUPES BigFoot Oribital Polishers
    Last Post: 10-07-2016, 04:20 PM
  2. How do you know if a MF towel is of good quality?
    By fastfurious23 in forum Auto Detailing 101
    Last Post: 09-16-2014, 12:14 AM
  3. Good quality car shampoo...
    By Lexi65 in forum Auto Detailing 101
    Last Post: 02-21-2014, 10:40 PM
  4. pads destroyed
    By SPIROS ANTONIOU in forum Auto Detailing 101
    Last Post: 05-22-2012, 06:16 AM
  5. Replies: 7
    Last Post: 03-15-2012, 08:56 AM
