Page 1 of 2 12 LastLast
Results 1 to 10 of 13
    Regular Member Thenissanguy's Avatar
    Sep 2014
    SoCal
    142
    which pads to order?
    Im looking to order some pads right now that there is a good sale going on, just have a few questions.
    I will be using these on my gelcoat rv. Also on some of my vehicles ( chevy , kia , toyota)
    i will also be ordering the Flex 3401 and HD Speed
    1. Which pad colors do i ? Which colors sound i double up on?
    2. Whats the difference from the 6.5 and 5.5 ccs inch lake country pads? i know the 5.5 are thinner but will they make a difference?
    3. Which pad cleaner is best
    4. Am i missing anything?
    Feb 2015
    470
    Re: which pads to order?
    Do not buy the CCS pads for the 3401 get the hybrids from lake country. Get the kit with a extra 4" backing plate for the 5" hybrid pads so you can use 5" and 6.5" hybrids. If your rides are in good shape the blue and white pads will be all you need for swirls and finish polishing. A 3401 will speed through a RV really nice with the 6.5" pads.This is the plate for 5" pads FLEX XC3401 Changeable Backing Plate System and these are the pads Lake Country Hybrid Power Finish Ultra Performance Pad System I hope this helps you make your choice.Also the HD cord is so nice and free today for the Elf promotion.
    Super Member dlc95's Avatar
    May 2013
    Rochester Hills, Mi
    6,016
    The 5.5" CCS isn't going to give you a safety margin for the back plate. The 6.5" will work just fine. The forced rotation 3401 doesn't have an issue moving 6.5" pads.
    I don't know how strong HD Speed is, but I typically use cleaner waxes with white or black pads. You might want to consider the pink, orange, or yellow to help give it more cut, because the gel coat is tougher than typical clear coats.
    I personally find the pink pads cut more than either the orange or yellow, and handle easier on the 3401. The CCS os a great pad line over all.
    Regular Member DetailTrail's Avatar
    Oct 2015
    129
    I'm waiting on more Buff & Shine Microfibers, cut and finishing. They have a thick foam body with a nice layer of Micro.
    Those babies will cut, and give a little compression room for contours, without bottoming out like the thinner versions.
    For pad cleaning, I use almost all of the liquid ones (diluted with distilled) & the powder soak (WG now BF), IMO they are about the same.
    I use the powder with a brush in a soak bucket, when the pads done, I spray it with pad cleaner, brush it some then throw it in.
    Clean them later when I have time, so the soak does it's work.
    May 2013
    Rochester Hills, Mi
    6,016
    Quote Originally Posted by DetailTrail View Post
    Yep, those are really nice pads too!
    Apr 2013
    East Coast
    178
    For the FLEX 3401 the HYBRID pad system with 5" pads are the best pads for the machine. They were specifically made for the 3401.
    1. Get the LC backing plate system with the 4" plate that was mentioned above.
    2. Get a combination of orange cutting and white finishing HYBRID pads for those two processes.
    3. You can buy both the 5" and 6.5" with the above backing plates but the 5" seem to work the absolute best for the machine.
    4. Meguires 5.5in Cutting pads will work wonders with the 4" plate also, makes for a heavier cut. Which might be needed on the Gel Coat or even the cars
    Any other variances from the above may also work for you on the machine, but since you need likely 5-6 pads each type those mentioned in my post and another will definitely work just perfect for you. Like I said, Lake Country developed the Hybrid system specifically for the Flex 3401. I spent 100's on different size pads and pads before actually listening to others and working with this system. I don't even try anything else anymore, due to how well it finishes down for me no matter what type of paint I am dealing with.
    Hope this helps and saves you some money
    May 2016
    Is your RV still like new or do you have some oxidation? If the latter you may want to look at the LC 6.5 purple foamed wool pads. Mike Phillips has several threads recommending those for the 3401 along with the M31 AIOs. I have a houseboat (floating RV) and like that combo. I do want to get the hybrid pad set up to try on our cars though.
    Super Member Paul A.'s Avatar
    Dec 2007
    Tampa Florida
    5,274
    I have to agree with those so far saying the LC Hybrids. I absolutely love the Lake Country Hybrid pads with my 3401 and use both 5" and 6.5". I would strongly suggest a good inventory of 6.5" for the RV. I go from purple foamed wool all the way down to the black/red pads for just about every condition of work needed. I gradually built up an inventory of 6 packs in almost every color in both size diameters however understand that may be costly right out of the gate. I would suggest 2 6-packs with 4 orange, 4 white and 4 black.
    And i have to thank Mike Ploesser (sp? sorry) at DedicatedPerfection for those pad recommendations. He was lazer spot on with those on the Flex!
    Sep 2014
    SoCal
    142
    Quote Originally Posted by wing commander View Post
    Quote Originally Posted by Puckman View Post
    thanks guys i will be ordering these hybrid pads once i get my gift certificate figured out! Now that i have been doing research on these pads i see great results!
  10. #10
    Sep 2014
    SoCal
    142
    Quote Originally Posted by Houseboater View Post
    well i ordered the oxidation removal kit thats for sale on here and it comes with a wool pad and the M31 AIO. Maybe i should order another wool pad
  1. Brand name or which pads to order
    By SLWKAT in forum Auto Detailing 101
    Last Post: 04-25-2020, 09:26 AM
  2. Need to order new pads
    By Gravediggr in forum Wool & Foam Buffing Pads
    Last Post: 08-04-2015, 04:50 AM
  3. Going to order pads, not sure if I need yellow?
    By WRAPT C5Z06 in forum Ask your detailing questions!
    Last Post: 01-30-2010, 07:01 AM
  4. Detailing an MX5. need help with pads order...
    By Damnhor2 in forum Auto Detailing 101
    Last Post: 04-12-2008, 10:43 PM
  5. LC CCS pads - different from previous order
    By Mr Dream Machines in forum Porter Cable 7424XP Dual Action Orbital Polisher
    Last Post: 12-30-2007, 07:44 PM
