Results 21 to 30 of 32
  1. #21
    May 2017
    Pittsburgh PA
    2,847
    Re: Fuzion paste wax help on black........
    Quote Originally Posted by pittpens24 View Post
    1st 2 pics are of the truck and last is my prize posessionAttachment 67306Attachment 67307
    Sent from my SM-G973U1 using Tapatalk
    I know pictures aren’t real life, but the truck looks great too.
    Obviously the Camaro is what dreams are made of.
  2. #22
    Aug 2013
    Tustin, CA
    4,389
    Black is my favorite color on rides and all I do know is that Black colors or dark colors just be extra careful or what I do is after the polishing stage I will use a pre wax product (I am using Gyeon Prep) and that will make sure your ride is absolutely ready for the wax. But you put a sealant on 1st. My guess too much product and I think you applied by hand if I stand corrected. I would still apply by DA. But you will remove the hazing with a simple clean. But either way I feel your pain! I am glad Mike helped you with this!
    Take care and KEEP ON ROCKING!
    CJ
    Save the Manual!
  3. #23
    Apr 2012
    7,494
    Wow that looks great! Next time around I will apply by machine to get a thinner coat.
    I agree about no protection with the Blacklight but it is just for that deep gloss. You saying the sealant looks better alone than the Blacklight topped with the Wgps?
    Yes, I'd skip the Blacklight all together. As a side note I've moved on to Polish Angel Centurion for my Genesis and been wiping it down with Beadmaker.
    2019 Nissan Rogue SL
  4. Likes PaulMys, SWETM liked this post
  5. #24
    Jul 2019
    101
    Quote Originally Posted by custmsprty View Post
    I use F11 as a protectant and maintainer. Beadmaker looks like a comparable product at a quarter of the price. How does it work for repelling bird droppings and bugs? After 3 coats of the F11, you can pretty much rinse off the bird dropping and bugs with a garden hose.
  6. #25
    Super Member rlmccarty2000's Avatar
    Dec 2013
    Fitzgerald, GA
    2,002
    If the humidity get to the 90 mark all kinds of problems pop up. Nothing cures right as everything stays damp. Heat is not too big of a problem, but that humidity can be a bear.
  7. Thanks pittpens24 thanked for this post
    Likes PaulMys, SWETM, pittpens24 liked this post
  8. #26
    Jul 2019
    101
    One last thing I need clarification on. So you put one coat of wax on, buff it off, final wipe and then do it a second time to insure 100% coverage. Is this possibly how I put too much product on? I was always under the assumption that you cannot "stack" wax coats - that the 2nd will etch into the previous coat, but it is looking to me like possibly the opposite happened?? Scratching my head here and being suoer cautious as I do not want this to happen on my Camaro. I also know hot, humid days are not ideal for detailing, but with cars shows upcoming, you do not always have a choice especially when it comes to polishing the wheels the day before
  9. #27
    May 2017
    Pittsburgh PA
    2,847
    A lot of people do two or more coats of waxes. More so than other products, waxes are said to sit on top of each other. I’m sure there is some mixing of the second coat into the first coat, but if they are the same wax it shouldn’t degrade the appearance hopefully.
    For whatever it’s worth, in my experiences with multiple coats of wax, I often see the nicest finish after two coats.
  10. #28
    Jul 2017
    310
    Question for the group and Mike specifically. You said to let the wax dry. Reading the directions on the AG website, it doesn’t sound like you let it dry (one section at a time, apply, remove).
    I just got my Fuzion and experienced an oily surface on a couple panels after buffing it off. I didn’t let it dry tho. Did I do it wrong?
  11. #29
    May 2017
    Pittsburgh PA
    2,847
    Quote Originally Posted by jdgamble View Post
    I’m not Mike but will partial answer. Fuzion can/should be wiped off before drying. Perhaps for the final buff at the very end, one may want to wait a bit if it’s humid out.. other than that I’ll let Mike explain his previous response.
  12. #30
    Super Member MarkD51's Avatar
    Oct 2012
    Sheboygan Wisconsin
    3,130
    My first thoughts, and a couple others have mentioned it I see, was to skip the CG Glaze. This possibly could as well been the culprit, a mixture of unlike products. I would think a glaze would offer zero in the way of additional pop with the use of WG DGPS 3.0 then Fuzion?
    What I'd maybe try on the Camaro, is a follow-up with a high quality detailing spray, such as Pinnacle Crystal Mist. A killer product.
  13. Likes acuRAS82 liked this post
  1. Fuzion Paste by Machine.
    By jankerson in forum Wolfgang Car Care
    Last Post: 12-07-2020, 04:52 PM
  2. Pinnacle signature paste vs black fire midnight sun paste
    By Cstamp3084 in forum Auto Detailing 101
    Last Post: 12-02-2019, 08:13 AM
  3. Fuzion Paste Trim Sealant * NEW!
    By swanicyouth in forum Wolfgang Car Care
    Last Post: 08-06-2012, 08:03 PM
  4. Durabale paste wax with fuzion like looks?
    By tw33k2514 in forum Auto Detailing 101
    Last Post: 02-20-2012, 07:55 AM
  5. Sov Paste vs. Fuzion?
    By img in forum Auto Detailing 101
    Last Post: 11-21-2008, 10:49 AM
» March 2024
2526272829 1 2
3 4 5 6 7 8 9
10 11 12 13 14 15 16
17 18 19 20 21 22 23
24 25 26 27 28 29 30
31 123456
