Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
    Super Member FUNX650's Avatar
    Dec 2010
    Ohio, USA
    21,057
    Re: How often to re-apply WDGPS3.0?
    Of course there are many variables that
    can affect the longevity of WDGPS, but
    I can expect to easily get ~3-6 months
    whenever I perform, just as you did:
    a back-to-back application of this Sealant
    (factor the 12hr. cure-time in between)
    •To maintain the characteristics of WDGPS,
    before its reapplication...I'll use:
    Meguiar's D114 ("leaves nothing behind");
    or, Wolfgang Instant Detail Spritz:
    It was "created to complement
    Wolfgang Deep Gloss Paint Sealant 3.0"
    Super Member pickles's Avatar
    Jun 2011
    477
    Refresh the sealant layer with WG QD and their spray sealant. That will keep your "buttery smooth" feeling.
  3. #13
    Jan 2014
    SoCal
    1,122
    I have (and have used a few times) all three of the products listed above. I would not count on the Quick Detailer adding much to the life of the sealant. You would be better off using one of the better quick waxes.
    The Spritz Sealant will add longevity to the sealant. But, be aware, It requires the same 12 curing time (w/o moisture), is supposed to be applied to a clean, bond-able surface and should probably be applied in the shade (not sure on manf. rec. here). In other words, about the same effort as putting on another coat of sealant.
    You could just use it as a detailer. But, you could also just wipe on another coat of sealant as a maintenance every month or two without paying for an additional product.
    Many options - you pick.
  4. #14
    Sep 2015
    6,281
    Quote Originally Posted by custmsprty View Post
    as often as you want too
    Ditto or just coat it.
  5. #15
    Nov 2015
    Arizona
    1,419
    What kind of longevity do you typically get using this method? Meaning how long from the point where you've clayed and layed down your base on smooth paint, till you clay again?
    Bob is right on the money. 3-6 months is a reasonable estimate. But it's just so hard to put a number on it. Some weeks I might wash a vehicle 3 times and others maybe not for 3 weeks. And in the winter it's always gone on the rockers loooong before anywhere else.
    Just an example... I put DG 105 on a vehicle this spring, maintained all summer with Aquawax, and it's still going strong. I'm confident it'll have another couple months left. Without that Aquawax maintenance, I don't think it woulda gone this long. Again, it's hard to say. But maintaining with spray waxes is just good practice. And it works.
    Regarding claying, on my own vehicles I do a thorough job once a year. Might hit the horizontal panels as necessary a couple more times.
  1. WDGPS3.0 on Detailer
    By IzzyMan12078 in forum Wolfgang Car Care
    Last Post: 09-02-2016, 03:46 PM
  2. when can I apply wax
    By hulatee in forum Auto Detailing 101
    Last Post: 03-14-2013, 08:27 AM
  3. How should I apply DG-105 ?
    By adrynalinjunkie in forum Auto Detailing 101
    Last Post: 11-29-2012, 01:52 PM
  4. Amount of time before buff off of wdgps3.0
    By unclestu in forum Wolfgang Car Care
    Last Post: 10-07-2009, 07:20 PM
  5. WDGPS3.0 2nd coat
    Last Post: 08-10-2009, 07:05 AM
