I did a 2nd coat on one vehicle and it was not worth the effort or excess use of the coating. Just take your time and do a good job with the first coat.
I keep it clean with the WG Uber Rinseless. Occasionally use the WG auto bathe if I go traditional.
Everyone, thank you so much for the advice and contributions. The car turned out great.
The ambient temp was 91 degrees, humidity at 70%, and a heat index of 102 degrees. This meant, I was only doing 1 coat LOL.
The weather definitely affected flash time, as it only allowed about 40 seconds to level out the high spots before they hardened. I found out the hard way (no pun intended) on the driver side front door glass.
Other than that trial spot, it was very easy to work with and I'm super happy with the results. Here are some pictures:
