Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
    Super Member The Guz's Avatar
    Jun 2013
    LA, CA
    8,719
    Re: Uber Ceramic Surface & Multi-Coat Options
    Try a second coat on one panel and see if you notice a difference in gloss.
    May 2014
    Northern Vermont
    1,400
    I did a 2nd coat on one vehicle and it was not worth the effort or excess use of the coating. Just take your time and do a good job with the first coat.
    I keep it clean with the WG Uber Rinseless. Occasionally use the WG auto bathe if I go traditional.
  3. #13
    Super Member natewood70's Avatar
    Dec 2010
    Royal Palm Beach, FL
    610
    Everyone, thank you so much for the advice and contributions. The car turned out great.
    The ambient temp was 91 degrees, humidity at 70%, and a heat index of 102 degrees. This meant, I was only doing 1 coat LOL.
    The weather definitely affected flash time, as it only allowed about 40 seconds to level out the high spots before they hardened. I found out the hard way (no pun intended) on the driver side front door glass.
    Other than that trial spot, it was very easy to work with and I'm super happy with the results. Here are some pictures:
    OVERALL:
    HOOD SHOT:
    CLOSE UP PEARL:
    A year from now, you'll wish you started today.
    @utopiandetailing on Instagram.
  1. Replies: 161
    Last Post: 10-29-2020, 11:12 AM
  2. We Uber ceramic spray coating over Uber ceramic
    By c62008 in forum Ask your detailing questions!
    Last Post: 06-20-2020, 03:57 PM
  3. Reaply Wolfgang Uber Ceramic Coat over original first coat
    By jeancaban in forum Wolfgang Car Care
    Last Post: 07-25-2016, 05:46 AM
  4. 303 Multi Surface cleaner question.
    By JWilliams.RadiantDetail in forum Auto Detailing 101
    Last Post: 02-28-2016, 06:59 PM
  5. WG Uber Ceramic coating or New Gloss coat ceramic forumla
    By Mike@ShineStruck in forum Auto Detailing 101
    Last Post: 12-19-2015, 01:42 PM
