» Detailing Classes
Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
    Senior Member ryanbabz71's Avatar
    May 2010
    Avon, Indiana
    751
    Re: 9th Episode this Sunday with Bruno Massel - What's in Autogeek's Garage?
    Thanks,
    I dont have the problem with it being not shiney, I have coated it with collinite 845 to protect it more than anything. I have a bunch of scratches in it that I need to get out. I have tried using the same product (optimum) that you used on the show and it works ok. Would a wool pad like you used be safe for it?
    Ryan
    Jun 2009
    Stuart, Florida
    43,961
    Quote Originally Posted by ryanbabz71 View Post
    If it's anodized I would say "no".
    If you start grinding on an anodized black surface with any type of abrasive and a wool pad on a rotary buffer you will grind through the anodized layer and reveal non-anodized aluminum.
    In the process you will change the look of the diamond pattern and you will only do it to a small area and then you'll have a shiny spot in the middle of the black surface.
    Anodizing isn't a coating "on" the surface, it's a coating that's a part of the metal itself. It doesn't like to be abraded with the intend end-results being that it will look original or good.
    Can you take a picture of it and post it? Can you somehow confirm that it is in fact anodized? Keep in mind in my previous post I was just taking a guess based upon your description, I could be wrong and don't want to steer you in the wrong direction.
    Mike Phillips Facebook Page
    Twitter
    Instagram
    Mike Phillips Detail Files YouTube Playlist
  3. #13
    May 2010
    Avon, Indiana
    751
    Here is a pic, I will find the manual that came with it and confirm
    9th Episode this Sunday with Bruno Massel - What's in Autogeek's Garage?-imageuploadedbytapatalk1338231300-106040-jpg
    Ryan
    Ryan
  4. #14
    Jun 2009
    Stuart, Florida
    43,961
    Ryan
    From the picture it looks like it might be powder-coated?
    See what you can find out...
    Also, this episode is on again today at 4:00pm
    Twitter
    Instagram
  1. Episode #12 of Autogeek's What's in the Garage on this Sunday!
    By Mike Phillips in forum What's In The Garage?
    Last Post: 10-12-2014, 05:43 PM
  2. 10th Episode on this Sunday! - Bruno Massel & Matt Steele
    Last Post: 06-05-2012, 07:50 AM
  3. 8th Episode on this Sunday - What's in Autogeek's Garage?
    Last Post: 05-28-2012, 02:50 PM
  4. 7th Episode on this Sunday - What's in Autogeek's Garage?
    Last Post: 05-14-2012, 04:15 PM
  5. 4th Episode on this Sunday! - What's in Autogeek's Garage
    Last Post: 04-25-2012, 07:59 AM
» November 2019
2728293031 1 2
3 4 5 6 7 8 9
10 11 12 13 14 15 16
17 18 19 20 21 22 23
24 25 26 27 28 29 30
