our factory wheels are clear coat over silver. I believe they are aluminum or similar. The clear coat is peeling in some areas and nonexistent in other areas. I was knocking some of the oxidation off with steel wool as it was easier than wet sanding. I wanted to smooth everything out then hit it with a few coats of clear. Do I have to remove ALL of the factory clear coating before i clear coat it? Or can i just smooth it out before laying my clear?
Thanks
