Re: 3™ Trizact™ Foam Discs 5000 FAQs
Originally Posted by ARTB155
Mike, sorry my mistake while reading your 1st post, was little bit tired and not concentrated.
So, you wrote about 1400-1800 speed of polishing after Trizact 5000 step is finished, not about speed 1400-1800 while using Trizact 5000.
Correct.
When I typed that it could have been before the low RPM rotary buffers became available or a "general recommendation", which I do often post.
Me? Often times when I'm compounding out sanding marks I stat around 1000 to 1500 RPM, except for severely oxidized boats I rarely use a rotary past 1500 RPM.
All clear now and if I understand well DA speed for wetsanding should be minimum one under which constant pad rotation is.
Thx
Correct.
If you have a lot of paint and confidence in yourself you can run your sander a little faster but for most of us... being careful trumps going fast when machine wet sanding.
Last Post: 11-13-2019, 02:58 PM
By Kdancy in forum Wet-Sanding, Cutting & Buffing
Last Post: 06-06-2019, 03:28 PM
Last Post: 02-03-2017, 08:53 AM
Last Post: 08-21-2012, 04:12 PM
By fredcandetail in forum Auto Detailing Tools and Accessories
Last Post: 03-14-2011, 08:39 PM
