Page 4 of 5 FirstFirst 12345 LastLast
Results 31 to 40 of 43
Like Tree5Likes
Thread: Dampsanding with 3" Griot's Garage Mini Polisher
  1. #31
    Senior Member JustJesus's Avatar
    Oct 2014
    Orange & LA Counties
    208
    Re: Dampsanding with 3" Griot's Garage Mini Polisher
    Quote Originally Posted by Dandy98 View Post
    Mike.. if you have a proflomiter handy I would like to see the results of depth of scratch with such and aggressive orbit and pad.Then follow with a finer grade. Measure again but this time get the RMS.
    Also with the coarser scratch I would have to believe that you are removing more clear coat.
    But I'm always willing to learn something new.
    I did such a test, but used a paint thickness gauge. And yes, clear coat IS removed.
    Here are the readings I took from my test panel. It was 3 light section passes using 1000 grit, followed by 1 section pass of 2000 grit, then followed by 1 section pass of compound. (Microns on left section, and mils on right section)
    LSNAutoDetailing likes this.
  2. #32
    Jun 2009
    Stuart, Florida
    36,317
    Don't have one...
    But the below is correct...
    Quote Originally Posted by JKDesign View Post
    The Griot's 3in machine has a 5mm orbit.
    Most pnuematic DA sanders for the collision industry are 3/16 to 5/16 orbit. That 5mm orbit lies very close to the 3/16. 1mm=.039in, 1/16in=.0625in
    The Griot's 3" Polisher is NOT an aggressive sander.
    It's perfect for people to learn machine sanding on and in my opinion perfect for machine sanding thin panels and close to body lines.
    With the 3M Trizact and Mirka Abralon discs it's an awesome tool.
    Host - Competition Ready on Velocity Channel
    IDA Board Member
    CD-SV, RT
    Competition Ready Facebook Page
    Mike Phillips Facebook Page
    Twitter
    Instagram
    Click on a book to get your own copy.
  3. #33
    Member
    Aug 2016
    Howell, Mi
    94
    Thanks for the info. The details about a 5MM orbit being closer to 3/16 " make sense now. I stand corrected. Like a plumber who cant fix a leak ! I still would encourage a soft interface pad. I learn something every day !
  4. #34
    Member
    Aug 2016
    Howell, Mi
    94
    Now that my curiosity is up I am going to test both on a factory clear , measure RA and RMS. Using AO and SC. Ill look in my bag tomorrow and start the tests later this week. Ill keep you posted. Also the data supports my above claim that it could eat through the clear and it did.
  5. #35
    Member
    Aug 2016
    Howell, Mi
    94
    Great test... I like data... it really did get through the clear which is what I suspected.
  6. #36
    Oct 2014
    208
    If you're referring to my post, burning through the clear coat was done on purpose. I was trying to see just how much force and/or passes it would take to get there. For that panel, I used WAY more downward pressure than I would in a real-world condition.
  7. #37
    Member
    Aug 2016
    Howell, Mi
    94
    Great footage and great product with the 3" System. I have a kit for 5",6" and 3" discs , back up pads and interface pads. If interested please do contact me or take a peak. : 6? Orange Peel Kit. Damp or Dry | Donald Pavlica Fine Arts
  8. #38
    Feb 2015
    Ft. Lauderdale,Fl
    393
    So I'm guessing the Rupes 75 is a bit too aggressive of orbit to do this for people who aren't used to doing it.
  9. #39
    Senior Member DaveT435's Avatar
    Jun 2012
    Arlington Texas
    3,095
    Quote Originally Posted by Whitewater25 View Post
    That or it wasn't available in 2011 when this thread was started...lol
    2015 F-150 Crew Cab Lariat
    2016 Chevrolet Camaro 2SS
  10. #40
    Senior Member CarolinasFinestDetailing's Avatar
    May 2011
    Indian Trail, NC
    1,532
    Look on page 2 of this thread:
    http://www.autogeekonline.net/forum/...es-mini-2.html
    Mike explains that he has never sanded with the Mini, but has with the Duetto, which is the same stroke. He concludes that you can sand with the Mini as well.
    I have sanded with the Mini as well and it cuts great.
    Carolina`s Finest Detailing - CQuartz Finest & Opti Coat Pro Authorized Installer
    When only the Finest will do...Let us come to you!!
    www.Carolinasfinestdetailing.me
  1. 3" Mini Polisher- Gen II - Griot's Garage Mini Polisher
    By Mike Phillips in forum Product Reviews
    Last Post: 12-15-2013, 08:05 PM
  2. Rupes Mini 12 vs Griot's Garage Mini Polisher
    By Mike Phillips in forum Ask Mike Phillips your detailing questions!
    Last Post: 11-13-2013, 12:57 PM
  3. Griot's Garage 3" Mini Polisher for Wetsanding Class
    By Mike Phillips in forum Wet-Sanding, Cutting & Buffing
    Last Post: 09-23-2013, 02:50 PM
  4. Griot's Garage 3" Mini Polisher - Extreme Demo - Warning!
    Last Post: 04-02-2013, 02:01 PM
  5. Replies: 9
    Last Post: 02-28-2011, 03:18 PM
» April 2017
262728293031 1
2 3 4 5 6 7 8
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
30 123456
