Page 3 of 3 FirstFirst 123
Results 21 to 25 of 25
  1. #21
    Dec 2014
    Boonsboro, Md
    2,724
    Re: clear coat burn from scratchx use?
    Quote Originally Posted by David Hayward View Post
    In my opinion the damage is already done if the clear isn't just hazed or marred. If you have compromised it from the scratch x then it's too late and can't hurt trying to go harder with the polish. The spot may increase in size if the clear is thinning out in the area though.
    ^I aggree with this. If you did cut through, it won't make it much worse.
    My car was egged last year and I cut through the clear trying to clean up the destruction it caused. I put Opti-Lens on the spot, it was the only coating I had at the time, and can still see the high spots today so I'm assuming it is still there protecting it.
    ____________
  2. #22
    Jun 2016
    So I should apply Meg's #7 and then 26 that might at least cover it up? Should I try spot repairing with something like krylon CC spray and then polish over to blend it in? Or jus go for a repaint?
  3. #23
    Nov 2009
    Pasadena, CA
    12,615
    If you went through the clear, you should see blue paint on the media.
    '03 Corvette Z06
  4. #24
    Super Member DaveT435's Avatar
    Jun 2012
    Arlington Texas
    3,982
    I also agree, at this point you don't have anything to lose by trying to polish. If your not getting any color transfer you shouldn't be through the clear.
    2015 F-150 Crew Cab Lariat
    2016 Chevrolet Camaro 2SS
  5. #25
    Super Member RaskyR1's Avatar
    Apr 2008
    Shakopee, MN
    3,733
    Quote Originally Posted by Dave59556 View Post
    Brand new car only a month old. Yes I started in circles, but then rubbed some horizontally. Looks like I'll have to have it repainted then...
    Most likely. I don't think there is anything you can do to make it perfect and the more you polish the larger the area will get. It definitely has the typical outline you'd see with a strike through and the way it looks to me it appears like pressure points from your fingers working in a horizontal motion, which is why I asked. I know it's a new car but it's not uncommon for brand new car to have had bumper or other areas repainted from damage in transit or on the lot. They could have easy spot hit an area with color and then recleared the whole panel or blended it in somewhere. If you're not actually getting any color transfer it could be you just struck through the new clear from a repaint and the outline is the OEM clear. Only scenario that makes sense IMO.
    Quote Originally Posted by CieraSL View Post
    http://Raskysautodetailing.com/
  1. Is this clear coat burn or not
    By estcstm3 in forum Auto Detailing 101
    Last Post: 04-13-2018, 09:12 PM
  2. Would clear coat burn be obvious?
    By jdgamble in forum Auto Detailing 101
    Last Post: 08-03-2017, 01:47 PM
  3. Possible clear coat burn
    By BennyHFP in forum Auto Detailing 101
    Last Post: 06-17-2014, 12:24 PM
  4. Did I burn through my clear coat?
    By Skimmer0220 in forum Off-Topic
    Last Post: 12-18-2013, 02:20 PM
  5. Can you burn through clear coat with a PCXP?
    By moparfan1986 in forum Auto Detailing 101
    Last Post: 12-15-2010, 12:55 PM
