Re: White powder why???
Great advice guys. I guess I must have been using way too much product, because I know I used much more than 2 pea sized drops.
When I have better weather here in a week (and a break from school work again)I'll give that a try.
I'm still glad I got the HD, because I don't have any AIO products.
So is it safe to say if using the Menzerna correctly, I should be experiencing NO WHITE POWDER? For those that missed my prior post, I am not doing this in full sun. Thanks for the help!:dblthumb2:
***EDIT*** Mike, do you prime a new pad buy spritzing it with something too? How?
You should only be seeing weight dusting at most. However you will see more dusting when compounding with a rotary and wool pad.
I do prime a fresh pad before use. A pad conditioner or a light QD not loaded with polymers or waxes.
http://www.autogeekonline.net/forum/...brid-pads.html
