Results 1 to 4 of 4
    Sep 2015
    Wet sanding.. will this Da polisher work?
    Hi guys,
    I've just had my car re sprayed and had the painter add 3 coats of clear coat so I can wet sand after.
    I have been offered a Das6 pro plus to do this. My question is will this be right for the job. I've searched the net a lot looking info and people seem to say that any more than 8-10mm throw will be hard to use.
    This machine has 15mm which is making me unsure where it is suitable.
    DAS 6 Pro Plus - 15mm Dual Action Polisher - Shop 'n' Shine
    Any advice would be greatly appreciated.
    Thanks,
    Craig
    Re: Wet sanding.. will this Da polisher work?
    I don't think it will be hard to use but be careful as it may remove a lot of paint very fast.
    IF you decide to use this tool then stick with high quality sanding discs from Meguiar's, 3M and/or Mirka. We carry all of these brands here at AG.
    There's a 8mm version by that same company I think, that would be an easier and safer tool to use.
    I teach using the PC, Griot's and Megs 8mm DA Polishers in my class on hand and machine sanding. They work great.
    Here's a very in-depth article on how to sand by machine....
    Damp-Sanding Tools, Tips and Techniques by Mike Phillips
    Here's a related article,
    Can the Flex 3401 be used to wetsand?
    While it's not safe to machine sand using a Flex 3401 for car paint I do show this for sanding gel-coat boats and aluminum pontoon boats in my boat detailing book.
    Sep 2015
    thanks mike for the info. Ive decided to go for one of the other type either a das6 500w or 900w.
    Firstly would 500W be enough to do this job comfortably or would I be better going for 900W.
    I will supplier images later today of the paint condition. I'm wondering whether I can use 3000-5000 grit or a velvet orange peel removal pad to decrease the orange peel instead of going 1500-3000-5000.
    is this possible of do I really need to start 1500?
  1. Recommend tools and polishes for sanding and restoration work on collector cars
    Last Post: 08-07-2018, 04:15 AM
  2. Use a DA polisher after wet sanding?
    By MJT in forum Auto Detailing 101
    Last Post: 09-09-2013, 06:27 AM
  3. Prep work for wet/dry sanding
    By Ncs0816 in forum Wet-Sanding, Cutting & Buffing
    Last Post: 12-19-2012, 08:37 PM
  4. Headlight Sander - Takes the work out of sanding headlights...
    Last Post: 05-14-2012, 03:37 PM
  5. will flex DA work for wet sanding?
    By tallyho in forum Auto Detailing 101
    Last Post: 01-28-2009, 08:56 PM
