» Detailing Classes
Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
    Jun 2009
    Stuart, Florida
    42,082
    Re: Can the Flex 3401 be used to wetsand?
    Zaid.... that looks GREAT!
    Nice work!
    Thank you for the follow-up...
    Mike Phillips Facebook Page
    Twitter
    Instagram
    Mike Phillips Detail Files YouTube Playlist
    Aug 2014
    165
    Mike, Somehow I missed your excellent post on sanding with the 3401.
    Around the first of November I tried the Trizact 3000 grit system on the Flex and also tried Meguiars Unigrit 1500 grit system with a spray bottle of water and a few drops of soap added.
    I found as you that it seemed a little too aggressive for my taste. It worked but not as good as the results I get with an electric random orbit da sander that I have.
    It runs at 12,000 OPM but the throw is very small.
    I got excellent correction and gloss using my PE14 and 3401, first with LC purple foam wool and then with a fairly worn orange LC CCS pad with Menzerna FG400. Correction was full with both pads and machines with the foam taking a little longer but with just as full of a correction and gloss as with the wool. I think one of my Hybrid pads would have worked better but I was just playing around and didn't want to mess up a new Hybrid pad.
    I wouldn't hesitate to sand with the Flex in a pinch but prefer the DA sander over all.
  3. #13
    Jun 2009
    Stuart, Florida
    42,082
    Quote Originally Posted by Garyhw48 View Post
    Yep... the Flex 3401 will work as a machine sandier but it's just too aggressive for my tasts...
    Maybe for gel-coat boats with heavy oxidation but again... any free spinning DA polisher will also do the job and do it a lot more safely or perhaps better wording would be a dual action polisher with a free rotating spindle assembly will sand material a lot less aggressively which is usually what you want.
    Exactly.
    I much prefer to work by machine for any process including machine waxing versus hand waxing, like this...
    There's lots of confusion over the term wetsanding and specifically when and where the majority of wetsanding is performed and I wrote an article to try to remove that confusion here,
    Wetsanding - Fresh Paint vs Factory Paint
    Twitter
    Instagram
  4. #14
    Jun 2009
    Stuart, Florida
    42,082
    Was just asked about sanding with a FLEX 3401 and shared this article and thought I would share what I wrote in the PM.
    Here's what I wrote...
    As far as sanding with a FLEX 3401 or ANY gear driven tool - you shouldn't do this on thin factory paint. I wouldn't even do it on thick custom paint.
    I TEACH using the FLEX 3401 to machine sand gel-coat boats and aluminum pontoon boats but they are THICK.
    Twitter
    Instagram
  1. Replies: 9
    Last Post: 10-17-2013, 05:20 AM
  2. Very hot Flex XC 3401
    By Jet Black in forum Auto Detailing 101
    Last Post: 08-23-2013, 05:15 PM
  3. Using the Flex 3401 to wetsand
    By zckid in forum Ask Mike Phillips your detailing questions!
    Last Post: 04-17-2013, 07:16 AM
  4. FLEX XC 3401, FLEX L3403, or FLEX PE14-2-150 for Gel Coat
    By MichaelD in forum Boat & Marine Craft Detailing
    Last Post: 10-16-2012, 01:28 AM
  5. ode to my Flex 3401
    By catfish07 in forum Flex Polishers
    Last Post: 07-14-2011, 09:59 AM
Members who have read this thread: 20
» April 2019
