Results 11 to 20 of 31
    Regular Member weeecho's Avatar
    Jan 2013
    119
    Re: How to remove orange peel by wet sanding - Advanced Detailing Class
    thanks for the answer with pictures and everything
    if someday i need to do this i will be really careful due to i only have this machine or do it by hand
    http://www.autogeekonline.net/forum/image.php?type=sigpic&userid=51683&dateline=136086  8845
    Quote Originally Posted by weeecho View Post
    No problemo...
    Sometimes the old fashioned way of hand sanding is the best choice.
  3. #13
    Jun 2013
    39
    Mike, sorry if it has been answered already but do you have an article of dry-sanding versus wet-sanding? When's the appropriate time and place to use either one?
  4. #14
    Quote Originally Posted by varga740 View Post
    I don't because in the past I have not been a huge fan of dry sanding not because it doesn't work well but for safety reasons and the dust it creates. Papers and discs tend to load up easier and faster and this uses up your paper and discs faster. $$$
    Check the forum tomorrow though and see what I post...
  5. #15
    I don't have an article at this time on dry sanding but I'll have one soon enough.
    There are benefits to both dry sanding and wet sanding, which I'll outline in the article. Dry sanding works great and makes it very easy to see your progress when removing defects like dirt in paint or orange peel, the thing to remember though is to always wear a respirator if you're going to do a lot of dry sanding, like sanding down an entire car, for health reasons.
    It also makes a lot of dust so just be prepared for the dust issue. Wetsanding is also messy but the dust is trapped in your sanding water and ends up on the floor, not all over the place or in your lungs.
    I'm really excited about the new flexible 3M Hookit Sheets although I wish they went to a higher grit level than #1500. There's probably a reason for this besides #3000 and #5000 are available in Trizact sanding discs although you can use the Trizact sanding discs by machine AND by hand.
    Check this out...
    Dry Sanding & Wet Sanding with 3M's Flexible Abrasive Hookit Sheets
    Here you can see the orange peel being removed as you look towards the bottom of the picture the orange peel is being removed leaving behind a very flat surface that after compounding and polishing will produce a smooth, high gloss finish with excellent Distinction of Image or DOI.
  6. #16
    Jun 2013
    39
    Thanks a lot Mike. I'll be Checking out your articles.
  7. #17
    Feb 2013
    95
    When will you be offering an advanced wet-sanding / damp-sanding & polishing class? How in depth will your January 2014 class get into this topic? Thanks.
  8. #18
    Quote Originally Posted by EliteDetailing View Post
    I cover this in all my boot camp classes...
    Next one is coming up in September... Click on the graphic at the top of each page that reads,
    Autogeek's Show Car Garage Detailing Boot Camp hosted by Mike Phillips
    Very in-depth. So in-depth that I'm proven right every time I teach the art of wetsanding.
    What am I right about?
    After a person learns how involved it is to wetsand a car from start to finish, (not just a spot but an entire car), without making a mistake, they tend to never want to do it again.
    How to wet sand a car
  9. #19
    Super Member Tato's Avatar
    Nov 2013
    Brazil
    2,157
    Impressive what you can do in ~8 minutes!
    I simply love watching your time lapses, I end up more tired watching than you doing this marvelous, show car work. How is it possible?!
    Sorry if this sound cliche, You're the MAN!
    Thanks for one more lesson.
    Kind Regards.
    ― Isaac Newton
  10. #20
    Oct 2014
    Hi mike, for PC DA, what is your speed setting?
  1. Wetsanding Class - 1949 Chevy Suburban Streetrod - Remove Orange Peel
    By Mike Phillips in forum 3-Day CAR Detailing Bootcamp Classes - Info & Dates
    Last Post: 12-20-2017, 08:21 PM
  2. Orange peel Wet sanding
    By frankprozzoly in forum Auto Detailing 101
    Last Post: 10-04-2015, 12:31 AM
  3. Damp sanding orange peel with what I have :)
    By jfoster in forum Ask your detailing questions!
    Last Post: 04-08-2013, 09:43 AM
  4. Replies: 24
    Last Post: 01-26-2012, 08:59 AM
  5. Wet sanding orange peel
    By FloridaNative in forum Auto Detailing 101
    Last Post: 09-20-2006, 04:32 PM
