Results 11 to 20 of 26
    Super Member Ron Atchison's Avatar
    May 2011
    Illinois
    1,034
    Re: Two Schools of Thought - Sanding in Straight-lines or in a Crosshatch Pattern
    Flash, What are you using the sanding disks with? By hand or with a machine? If you’re talking about machine sanding with disks then technically you are still sanding in a circular motion but in much more tighter controlled uniform circular motion. Circular sanding by hand lacks the uniformity because there will be areas that will be sanded more than others.
    May 2011
    Illinois
    1,034
    Crosshatch sanding can also prevent you from over sanding. By sanding in a 90 to the first sanding step you can see when you have removed the scratches and know when to stop. Sanding in the same direction can make it difficult to know when you have removed the previous papers scratches. Which can then lead to over sanding and causing problems such as not having enough paint left to make the correction or having to resand after a polish because the deeper initial sand marks are still there.
  3. #13
    Apr 2009
    176
    Crosshatch sanding can save time in the long run:
  4. #14
    Regular Member ohmy34's Avatar
    Jan 2011
    decatur al.
    118
    I've found that each type of sanding has it place for what you are working on. large flat panels - crosshatch, thin straight panels-straight line, small circles for round or ball type surfaces. jonathan
  5. #15
    Super Member Flash Gordon's Avatar
    Feb 2010
    Memphis, TN ~ USA 1
    10,450
    I think I'm going to try the Crosshatch method next time around
  6. #16
    Super Member CEE DOG's Avatar
    Jul 2009
    Florida
    7,358
    Good thought provoking thread, Thanks Mike
    :dancebanana:
    Sky's the Limit Car Care
  7. #17
    Super Member TS656577's Avatar
    Nov 2008
    South Central, Pennsylvania
    754
    Mike very well done, as always. Wetsanding is something that I've done in the past (mainly on headlights but on paint as well from time to time).
    Mike, I have a question now. You say sanding in circles makes it difficult to get uniform paint/clearcoat removal. This makes sense. Now just so I'm clear, random orbitals rotate, but because they're machines, the paint and clear coat removal is more uniform and easier to control pressure as opposed to hand sanding?
    Trent
    PRD
  8. #18
    Feb 2010
    Memphis, TN ~ USA 1
    10,450
    Quote Originally Posted by TS656577 View Post
    Kevin, I would like to hear your thoughts too!
  9. #19
    Apr 2009
    176
    Quote Originally Posted by Flash Gordon View Post
    Thanks Flash... I think I'll butt outta' this thread or change my name to Mike.
  10. #20
    Feb 2010
    Memphis, TN ~ USA 1
    10,450
    Quote Originally Posted by Kevin Brown View Post
  1. Replies: 3
    Last Post: 05-02-2019, 09:05 AM
  2. Replies: 4
    Last Post: 01-08-2019, 09:56 AM
  3. Mysterious crosshatch scratches on front hood
    By lexusgs in forum Auto Detailing 101
    Last Post: 01-04-2016, 12:16 PM
  4. Detailing Schools
    By godoman in forum Porter Cable 7424XP Dual Action Orbital Polisher
    Last Post: 01-25-2012, 03:14 PM
  5. Circles or Straight Lines?
    By DC08SI in forum Auto Detailing 101
    Last Post: 06-22-2008, 06:28 AM
