Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
    Super Member Dr Oldz's Avatar
    Aug 2010
    NE PA
    4,462
    Re: Rotary with urofiber 50/50 microfiber pads
    Quote Originally Posted by Noamtasini View Post
    I've used rotaries.. Never had any issues. Lack of common sense and recklessly applying the tool will get you the above. Never happened. Ever.
    Either way thanks.
    I accept your challenge! I love to see a video of you finishing down perfectly on black paint with a rotary without the use of glazes or fillers!!! Especially when you questions seem a bit on the newer to polishing side.
    By no means am I knocking you here, but perhaps try cutting with a rotary if need be and then finishing down with a DA.
    Jim
    Nov 2020
    Finishing with a rotary is done by thousands. It's not some secret artistic unicorn of a trade. I've done it in the past with low speed and pressure with a soft finishing pad.
    I was just asking about the pairing up of microfiber pads and a rotary. Which some have succeeded with as well. Obviously trickier and not as recommended as wool/foam.
    I'll probably just do B@S urofiber wool(supposedly they finish remarkably well)on a test spot, and finish with a soft foam if needed.
  3. Dislikes DanaDetailingPros disliked this post
  4. #13
    Super Member Jacob Harrod AUTOCLEAN's Avatar
    Mar 2020
    El Reno, Oklahoma
    754
    Please check out this thread. I was going to try to correct this hood with a rotary at first but found that a free spinning DA and a fiber pad followed up with a one step polish was a better option. The car turned out great and still does to thus day.
    I don't know what your vette looks like, but the hood on this little Ford was really messed up. I think there were even scratches from one of those car wash brushes that people scrub their wheels with and leave laying on the ground.
    Looks like its past the point of no return or just severely oxidized? Can it be fixed?
  1. Replies: 4
  2. Microfiber Pad On A Rotary - Don't Do It!!
    By theparmachine in forum Auto Detailing 101
    Last Post: 11-26-2012, 03:07 PM
  3. Microfiber pad vs Foam pads on a rotary buffer
    By JorgeSFL in forum Rotary Buffers
    Last Post: 05-02-2012, 04:13 PM
  4. Meg's Microfiber pads Vs Optimum Microfiber pads
    By SalFoges in forum Auto Detailing 101
    Last Post: 04-21-2012, 06:49 PM
  5. Replies: 5
    Last Post: 10-17-2006, 02:19 PM
» March 2024
2526272829 1 2
3 4 5 6 7 8 9
10 11 12 13 14 15 16
17 18 19 20 21 22 23
24 25 26 27 28 29 30
31 123456
