» Detailing Classes
Page 3 of 3 FirstFirst 123
Results 21 to 23 of 23
  1. #21
    Senior Member Paul A.'s Avatar
    Dec 2007
    Tampa Florida
    4,735
    Re: 1st time machine compounding, a bit disappointed
    Glad to hear it worked out garberfc! Menz HCC400 is a phenomenal product.
  2. #22
    Senior Member TTQ B4U's Avatar
    Jan 2016
    Central Ohio
    4,306
    Quote Originally Posted by garberfc View Post
    Hello All, I'm trying to compound out some scratches in my daughters 2016 Toyota Camry. She has some shallow and some deep scratching.
    I'm using a Rupes LHR 15 Mark III, with Lake Country yellow waffle pad, and Turtle Wax Rubbing compound. I made numerous horizontal and vertical passes using my 4 beads of compound at a speed of 4-5. I used a micro fiber cloth to clear the film. I was expecting at least the shallow scratches to be affected. I didn't even get a 'glaze' in the clear coat. I repeated the process, still no glaze. I did see a reduction in swirl marks.
    Any advise? Should I be using a more aggressive compound? If so, can you recommend any?
    Thank you in advance,
    F
    Rubbing compound as in the old gritty paste in a can kind? IMO, ditch that stuff. Not sure what you mean by Glazing a clear coat?
    End of day if you don't have a Paint Thickness Gauge, I wouldn't go chasing Random deep scratches. Remember, you're not "removing" scratches, you're leveling aka removing clear coat from the surrounding area to reduce the appearance of scratches. That means you're thinning out things and there's a balance between doing that to remove swirls which is okay and getting into trouble chasing deeper marring.
    My advice is that you don't likely need to compound anything and would be better off using a polish over the finish and getting it 90-95% corrected and leave the remaining 5% alone. Toyota has soft thin paint so tread lightly.
  3. #23
    Jun 2009
    Stuart, Florida
    44,380
    The Menz HC400 did the job! I used it with the Meguiars microfiber cutting pad. I removed or vastly improved numerous shallow scratches and mars in the clear coat.
    The Menzerna HC400 = GREAT ABRASIVE TECHNOLOGY
    The FIBERS that make up a microfiber pads are also a form of abrasives.
    So you had 2 things cutting for you not just the compound.
    You can see in the image what I did with the Turtle Waz rubbing compound!
    Sorry, try as I may, I keep getting a file upload failure.
    Yeah, getting pictures onto a "vBulletin forum" for the majority of people is simply not doable. It's too complicated. I sent our IT staff an e-mail with a recommendation to look into switching us over to XenForo forum software shared in my article below but never heard back from anyone.
    The easy way to share a picture on a forum - Tapatalk App for your cell phone
    Quote Originally Posted by TTQ B4U View Post
    Abrasive Technology - THE most important factor when it comes to polishing paint
    Mike Phillips Facebook Page
    Twitter
    Instagram
    Mike Phillips Detail Training Credentials
  4. Likes AZpolisher15 liked this post
  1. Can orange peel be removed or lessoned by just machine compounding?
    By Mike Phillips in forum How to articles by Mike Phillips
    Last Post: 02-25-2019, 04:49 PM
  2. Disappointed with packaging this time
    By cay7man in forum Customer Comments
    Last Post: 09-20-2017, 09:42 PM
  3. Time to wait before compounding after dr colorchip
    By rypkr937 in forum Ask Mike Phillips your detailing questions!
    Last Post: 08-21-2015, 07:14 AM
  4. first time wet sanding and compounding, little uneasy
    By Andr3wilson in forum Rotary Buffers
    Last Post: 06-13-2012, 04:18 PM
  5. Time machine?
    By abrcrombe in forum Off-Topic
    Last Post: 03-15-2007, 02:52 PM
Members who have read this thread: 129
» December 2019
1 2 3 4 5 6 7
8 9 10 11 12 13 14
15 16 17 18 19 20 21
22 23 24 25 26 27 28
29 30 31 1234
