Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
    Newbie Member Paint Correction God's Avatar
    Mar 2018
    Maryland
    Re: Cutting with HF DA?
    You can have the best polishers money can buy, but if you do not have a good system in place to work with that tool then your not going to get good results, The difference from a quality polisher and a low end polisher is going to be in the amount of passes need to make before removing defects in the finish. A harbor freight require 3-4 cycles before achieve the defect removal your looking to reach before finishing to where a quality machine would only take 3 passes and 1 cycle.
    Nov 2015
    Los Angeles, California
    13,729
    Quote Originally Posted by Paint Correction God View Post
    So I’m guessing you consider the GG6, Meguiars MT300, Porter Cable, and every other 8mm polisher to be low quality and basically inadequate for any kind of actual defect removal eh? Because I know for a fact from having used all those polishers and then some that they’re all more alike than not.
  3. Likes dlc95 liked this post
  4. #13
    Mar 2018
    Maryland
    Well if you read my post correctly you will see that I’m stating that you can get the job done with any polisher out there, it’s just going to take longer and be less comfortable.
    Crystal Clear Detailing
    - Facebook: facebook.com/CCAutoDetail/
    - Instagram: @paintcorrectiongod
    - Email: Ccservicesx@gmail.com
    Instagram: @PaintcorrectionGod
    Follow the fun! over 3,000 others are!
  5. #14
    Nov 2015
    13,729
    Cutting with HF DA?
    In the 4yrs of owning the HF polisher I’ve never not once experienced a time when I had to do 3-4 polishing cycles to remove defects and something like the GG6 could’ve done it in 1. And no it doesn’t vibrate more either...
    I know that mentioning, let alone praising the HF polisher is frowned upon here, but that’s such a bogus statement.
  6. #15
    Mar 2018
    Maryland
    No point in moving forward with this conversation, obviously your not getting the point... and how did any of the Griot’s line of polishers come into this lol? Anyway good night sir.
  7. #16
    Nov 2015
    13,729
    Cutting with HF DA?
    I’ll admit that I was wrong to bring the GG6 into this... It’s just not everyday that I see someone makes a blanket statement of basically calling all 8mm polishers “low end” vs. large throw polishers being “high quality”
    Correct me if I’m wrong, but that’s basically what you’re saying, is it not?
  8. #17
    Super Member dlc95's Avatar
    May 2013
    Rochester Hills, Mi
    6,016
    It's because the whole statement regarding having a good system contradicts the part about "low end" polishers needing more passes.
  9. #18
    Newbie Member BellyUpFish's Avatar
    Jun 2013
    I don't know much, but those might work well.
    Repeated linking and recommendations of products not available through Autogeek.com may result in a permanent ban.
    Thanks for understanding, I know you're just trying to buff stuff out but there is a company that pays the bills around here and it's no Amazon, or eBay or Harbor Freight.
    I appreciate you not giving me the axe just yet.. I actually reread my post, after I made it and hoped it didn't sound like an advertisement. I have no knowledge nor have I ever used their product. Ran across a YouTube video and thought I'd give it a shot.
    I appreciate your suggestions about the GG6. I'll consider it.
    Lots of choices out there.. I really don't have a budget in terms of affordability, but it seems counter productive to go buy the best when I may only use it a couple times a year. Also seems silly to buy the worst if it's a clear failure in the making.
    I unfortunately have a 1,500' gravel driveway, so uber detailing sometimes goes by the wayside on my daily drivers. I do have a couple weekend toys that would enjoy the treatment though..
  1. Cutting
    By JAMM0N in forum Wet-Sanding, Cutting & Buffing
    Last Post: 12-12-2014, 05:51 PM
  2. cutting
    By zkilo in forum Wet-Sanding, Cutting & Buffing
    Last Post: 06-05-2014, 04:01 PM
  3. CG V36 not cutting it
    By runrun411 in forum Auto Detailing 101
    Last Post: 09-26-2013, 08:12 PM
  4. 3m sr not cutting it.
    By h00ligan in forum Auto Detailing 101
    Last Post: 05-09-2011, 09:10 PM
  5. Cutting Pad
    By RPM06 in forum Porter Cable 7424XP Dual Action Orbital Polisher
    Last Post: 07-13-2006, 06:42 PM
