Page 10 of 12 FirstFirst 123456789101112 LastLast
Results 91 to 100 of 114
  1. #91
    Super Member mwoywod's Avatar
    Apr 2016
    881
    Re: Rotary VS Dual Action for Compounding
    Just that with the precision you can get with the rotary is why I'm intrested to learn to handle a rotary polisher. Maybe with the lower operating speed with under 1000rpm and lower makes the rotary safer now days. And even lower speed in the beginning. Is it possible with right technique on rotary to handle it as a weekend warrior? I think why many new people that are starting out to polish cars go the safe route start with a da.
    Have someone tested twisted wool/acrylic cutting pads and or low hair hight wool cutting pads on a da? And if you they cut faster than a mf cutting pad?
    Absolutely a weekend warrior could learn it! Especially since you have about 3x as much knowledge as most weekend warriors. I taught myself with the Dewalt 849x. Mike could give much better advice but I think if you start out using a heavily lubricated finishing polish like HD Polish+ or Jescar Finishing Polish on a lambswool or foamed wool pad and keep your machine speed between 600-1000rpms you would build your confidence and have the hang of it in no time!
    Once you move onto using a cutting compound, I would start out using compounds that have more lubrication. Jescar Correcting Compound is fantastic on a rotary. Jescar isn't my favorite compound on DA but it's lubricating oils make it ideal for rotary use.
    Stay away from compounds with short buffing cycles HD Cut+, 3D 501, M105, etc. They aren't necessarily bad compounds, but they dry up quickly and you'll feel the increased friction when using them. Especially when compared to compounds like Jescar, M100, Sonax CutMax, Scholl's S3 GoldXXL.
  2. Thanks SWETM thanked for this post
    Likes SWETM, DBAILEY, dlc95 liked this post
  3. #92
    Apr 2012
    604
    Quote Originally Posted by jslym777 View Post
    Tape off vulnerable edges? Doing this will also protect the pad from damage too.
    You missed the point completely.
  4. #93
    Apr 2012
    604
    Quote Originally Posted by mwoywod View Post
    When using a rotary paired with a wool/lambswool pad and a machine speed set between 600-1400rpms and you are cognizant of reducing machine speed to 600-1200rpms on plastic front and rear bumpers...as long as the lubrication of your compound hasn't dried up it's virtually impossible to burn paint. I've been using the rotary on a daily basis for the past 4+ years without ever burning paint. Actually, the only polisher related mistake I've made was before I owned a paint depth gauge and struck through porsche clear coat using a PC7424xp and a 3" megs microfiber cutting pad.
    My point is that there is a risk factor regardless of what machine you are using.
    Great. However my point was that the rotary has a greater risk factor than any DA on equal paints.
  5. #94
    Aug 2013
    Tustin, CA
    4,389
    IMO I so no reason why NOT to use a rotary for compounding and following up with a polishing compound with a DA. I have never used a rotary as IMO I have a Hybrid with the Flex 3401 Forced rotational DA. But I also think it's the talent of the Detailer that can use and machine whether it be a rotary or a DA.
    So if jslm777 uses a rotary for compounding and a DA for polishing...I say GO FOR IT!
    CJ
    Save the Manual!
  6. #95
    Super Member jslym777's Avatar
    Oct 2010
    308
    Quote Originally Posted by RZJZA80 View Post
    Not missing the point, I'm saying could have avoided it by preventative measures. Taping vulnerable edges is still necessary for the same reason whether or not you're using a DA or Rotary. We are also way off topic but I figured I'd entertain the heat issue or non-issue for a little.
  7. #96
    Jun 2013
    Montreal, Quebec
    3,996
    Ok but if you have to tape every edge on the car that adds a lot of time to the buffing job. I very rarelly tape when I do a compound, and when I do is for a part that I know I will have no choice but to go over because of the shape of the pannel. Granted since I don't do it often, I am not good at taping and it does take me a lot more time than someone who tapes every job, but still... Also tape is very expensive, so that adds more expenses to the detail, which is not a good thing.
    You guys seems really eager to prove that the rotary is superior. I would say it has advantages and disadvantages that probably puts it on par with a good DA. So if I was a new detailer, I could go either way and find success with either method. But after using a DA for 5 years, I feel like I have mastered it's use and don't really see a point to switch to something different that in the end will produce a similar result. But that's just me.
    Also, you keep saying heat is not an issue you want to talk about, and burning through is not a problem... yet, that is pretty much the only reason people are not using rotaries.... or at least the main reason. So if you want to keep that out of the discussion, there is no discussion.
  8. #97
    Oct 2010
    308
    Quote Originally Posted by Calendyr View Post
    Heat used to be more of an issue as compounds had shorter working times, rotaries were used at higher speeds, and people were relearning how to use rotaries on newer paints. Just as DAs have come a long way, so have rotaries. I don't have the mindset that you should only do detailing one way. My troubles and questions stem from the marketing aspects of the new DAs. The claims they make that you can get perfection, don't need skilled detailers anymore and can do perfect paint correction in shorter times with no risk. I just don't agree with all of that and to me sounds gimmicky, lowers the perceived standard of a professional and lowers the prices detailers can charge for paint correction.
  9. Likes dlc95 liked this post
  10. #98
    Apr 2016
    881
    I'm not sure if you are also referring to me when you say "you guys seem really eager to prove rotary is superior". But, I've made it clear that I personally am more comfortable with rotary and lambswool than I am with long-throw and x-tra cut microfiber. I also made sure to clarify in several different posts that it all comes downs to the operators personal preference and comfort level and that neither tool is truly superior across the board.
    As someone who utilizes both tools, I was eager to share my experiences and findings.
    You on the other hand, as someone with little to no experience with a rotary polisher still felt confident enough to use the following simile "I don't need to kill myself to know that pointing a gun at my head and pulling a trigger can be fatal" when referring to why you wouldn't use a rotary polisher.
  11. #99
    Jun 2013
    Montreal, Quebec
    3,996
    Well I would not say no experience, I have used it a few times. One thing I can tell you is that it's pretty stressful to use. If you come close an edge with the pad rotating the wrong way you can damage the car, if you stay in one spot for a short time you can damage the car, if you go too close to the edge you can damage the car... and so on. I have none of these issues with a DA. So yes, I feel there are very real risks that I am not comfortable being exposed to by using a Rotary and will only use it if nothing else works. I am happy for you that you have experience with the tool and feel there is no danger. But I am sure that wasn't the case when you first started using it.
    There are videos on Youtube from a guy called Cereal Marshmellow (or something like that). He owns a used car dealership and puts up detailing videos all the time (at least used to). And in one of his videos, his untrained assistant burned the paint on a car using a rotary. So if you think it can't happen, I would say it can, and it does. Now, I am sure if I had 5 years experience with a rotary I would not have any fear of it... the problem is I am not willing to pay for paint on customer cars (or my own) to learn.
  12. #100
    SELF BANNED
    Sep 2017
    570
    To clarify, just because a rotary CAN burn paint doesn’t mean it WILL. They not so unforgiving or lethal as people make them out to be - forums tend to add to the drama. A rotary is still smoother and quieter to use than any DA. The DA’s are safer and leave a nicer finish. I have finished many paints with a rotary so yes they can finish well too. Modern DA’s are preferred as theres no real reason anymore to reach for a rotary, but I feel they still have a place.
  13. Likes DBAILEY, mwoywod liked this post
  1. AIO Buffer (Rotary+Dual Action)
    By asap2stacks in forum Auto Detailing Tools and Accessories
    Last Post: 07-25-2017, 05:06 PM
  2. Rotary or G110 Dual Action Polisher
    By dhsv2 in forum Auto Detailing 101
    Last Post: 09-02-2014, 11:01 PM
  3. Dual Action or Rotary?
    By sabresfan in forum Rotary Buffers
    Last Post: 09-07-2012, 01:31 PM
  4. Dual action or rotary polisher
    By surajprasade in forum Ask your detailing questions!
    Last Post: 12-05-2011, 02:45 AM
  5. Rotary vs Dual Action
    By AndrewBall in forum Ask your detailing questions!
    Last Post: 09-22-2010, 09:27 AM
