Re: Help Needed - Post Body Shop Wet Sand And Buff Repair Question
Originally Posted by
Hard to tell from the pictures if the paint is just dull or if the clear is missing.
Basecoat is DULL so if they removed too much clear and exposed the basecoat then it will look dull.
IF they didn't get all of their sanding marks out then sanded paint looks dull.
The only way you can tell and it's kind of tricky - you need a dark cloth like a chunk of black t-shirt and a grey polish. Rub some grey polish with the black t-shirt over a dull area. If you see white paint coming off then the clear is missing. If the t-shirt and grey polish is all you see then the clear is still intact. At this point, you should be able to rub longer with a quality polish and see clarity and gloss come back to the dull paint - that is if the clear is still present.
IF the clear is gone then the only recourse is to repaint.
What do you have for compounds and polishes?
Sorry to hear of this mishap - I'm sad to say your experience is the norm for most body shops.
Thanks, Mike. I very much appreciate your insights.
I currently don't have any compounds or polishes, but if the clear coat is still there, I will definitely buy any recommended pads and compounds/polishes.
I am going to buy a little bit of the grey polish now to test a small area with a black t-shirt as you suggested. What kind of polish or compound would you recommend for this?
REALLY hoping the clear coat is still there
Thanks again to all of you for your help!
I don't think that the polish being grey is that important. You just need a polish that are not white so its easier to tell the difference on the black cloth between the polish and the car's white base coat.
DBAILEY
I agree that a person doesn't need a polish is grey - the problem is it's about the only other color that's dark and on the market. Most compounds and polishes are white and there are a few polishes that are grey.
The BIG PICTURE is that you cannot test for WHITE paint (easily) using things (cloth and polish) that are also white. The reason why is because the human eye will not be able to distinguish between the cloth, the polish and any removed white paint in a situation like this where you're trying to find out if the clear layer of paint is now removed.
Make sense?
But yeah... any color will do, whatever you can find, the darker the better so that if white paint is coming off the panel as you rub it will build up on the dark cloth with the dark colored polish so your eyes can see it and then you can make a definitive judgment as to whether or not the clearcoat is missing.
Honais
Thanks so much to everyone for the quick feedback. I will follow Mike's recommendation for the black shirt and gray polish and will post once I know if the clear is indeed gone.
What is a good gray polish to use? (Maybe something I could buy locally to check this out tomorrow?)
Thanks again,
I don't think you'll find compounds or polishes at the retail level that are not white.
Most retail waxes are actually cleaner/waxes, they simply don't state that in the name on the bottle. Perhaps if you could find one of those gimmicky "colored waxes" that would work. Maybe at the Dollar Store?
Honais
Doing a full write-up today on an old 2-door Chevy out in the garage, it will show you how to tackle your car.
Honais
Click link - follow along
One-Stepping a 1971 2-Door Chevy - Facebook Live videos
Awesome community here and I am floored by all the help, guidance, and support provided. I will post an update with pictures as things come along. Thanks again gentlemen!
