Page 1 of 2 12 LastLast
Results 1 to 10 of 14
    Regular Member OptimumAutoSpa's Avatar
    Oct 2016
    North East
    116
    Polishing newly painted panel
    Long story short... the quarter panel and fenders got some new paint and im curious how soon I can polish... i know sealant / wax is 30 days minimum but I figured I would do a mild paint correction while I wait.
    Re: Polishing newly painted panel
    Quote Originally Posted by OptimumAutoSpa View Post
    Long story short...
    You can normally start any sanding and buffing process a few days after the paint has been sprayed.
    The sooner you start sanding and buffing "generally speaking" the easier it will be to remove your sanding marks because the paint will still be more polishable. I wouldn't say it's soft but I would say it will not have reached full cure and hardness. What I have seen when paint is sanded and buffed too soon is the surface appearance changes for the worse and you'll see what looks like dull splotchy areas, sometimes you'll see sanding marks that you "thought" you removed re-appear.
    The longer you wait, the more the paint will dry and do any shifting it's going to do and then when you sand and buff, the results you see are the results you get.
    What are you working on?
    What type of paint was sprayed?
    Super Member TTQ B4U's Avatar
    Jan 2016
    Central Ohio
    5,438
    Just had the same situation and HIGHLY recommend 3D AAT 505. It's silicon free and 100% awesome stuff and fresh paint safe. I'm so pleased that I'm going to use it going forward on more details. The key is to not use any products with silicon or anything that will prevent the paint from gassing off. My car was sprayed with BASF Paint and they recommend 30 days for summer temps.
    2023
    In time out
    May 2016
    745
    Quote Originally Posted by pdqgp View Post
    Someone hit the Audi man?
    Jan 2016
    Central Ohio
    5,438
    Quote Originally Posted by idriveblackcars View Post
    Yep. Good news is the car is beyond perfect. I fought the other guys insurance but got both doors replaced not repaired and the paint works is beyond outstanding.
    https://www.autogeekonline.net/forum...ml#post1500623
    2023
    In time out
    May 2016
    745
    Damn brand new doors! Sweet
    Feb 2017
    72
    Why would you start sanding a panel that was just painted? I mean, polish/wax/seal, I understand.. but isn't wet sanding for defects? A new panel shouldn't have defects.
    Jan 2016
    Central Ohio
    5,438
    Yep. The level of detail they put into fixing it is amazing. The shop doesn't re-use any nuts, bolts or clips, bumpers, nothing. They collect them all upon disassembly and replace them with all new parts. I'm very pleased.
    2023
    Dec 2016
    32
    Quote Originally Posted by amalik View Post
    you would sand a freshly painted panel to take out the orange peel sprayed and get rid of the "trash" in the paint, or even to texture match to a existing panel. different grits leave different texture/orange peel. Also waxing a fresh panel is not recommended as the panel will not be able to gas out "breathe". You have to wait a month or two at least.
  10. #10
    Feb 2017
    72
    Quote Originally Posted by coopermosley View Post
    While I understand what you're saying, Wikipedia says orange peel is the result of improper painting. I would think there wouldn't be orange peel when a shop did the job perfectly, as OP said they did.
  1. Applying Sealant To Newly Painted Hood?
    By wolfpack1 in forum Auto Detailing 101
    Last Post: 03-05-2019, 06:02 AM
  2. Replies: 8
    Last Post: 04-17-2016, 10:16 AM
  3. Newly Re-painted - Any safe-to-use Car-wash/soap?
    By Crist Clapper in forum Auto Detailing 101
    Last Post: 08-29-2015, 06:35 PM
  4. How and when should I detail my newly painted 4Runner?
    By Drummer1 in forum Ask your detailing questions!
    Last Post: 01-28-2013, 09:56 PM
  5. Which QT to use on a newly painted surface
    By TSIFREAK in forum Auto Detailing 101
    Last Post: 07-30-2008, 07:34 PM
