quick question regarding 3m trizact
hello.. can someone explain how this is different compared to a regular wet sand paper? can this attach right onto my PC with its backing plate? or do i have to buy the soft interface pad?
3M Trizact 6 Inch 3000 Grit Performance Sanding Disc 01459, 3M sanding discs, 3M sanding pads
Re: quick question regarding 3m trizact
I am in I have old real old trizact and my Velcro paper will not stick to my da backing plate and I do have the soft inter face pad that will not stick to da backing plate
So I also need to know
You can use Trizact by hand or machine.
Regular wet/dry sandpaper will not attach to a hook-n-loop backing plate.
It will attach to any velcro/hook backing plate. Technically you need a 6" backing plate, not a 5" and Meguiar's makes one specifically for machine sanding but any 6" will do. The Megs unit has tapered edges so it will bend back (a little) for sanding into curved areas.
Use without interface for knocking down orange peel
Use with interface for refining deeper sanding marks.
thank you mike! what speed on the PC would you sand with?
I recently bought a mini cooper whos hood was repainted.. the hood does not have orange peel but also looks very hazy even after a nice polish.. im hoping this will sand it nicely and then i can polish to make it look perfect!
With the PC you normally have to be on the 5 to 6 speed setting.
Here's the deal - you MUST maintain pad rotation. The PC is kind of weak and their speed controller inside the unit also doesn't work very well.
So while you don't want disc stall you also don't what to be grinding and that's the balance between speed setting 5 and speed setting 6.
So I tend to run the PC on the 5 to 5.5, it you have to run it at 6 to maintain pad or "disc" rotating then don't stay in one area for too long.
My guess is machine sanding followed by some compounding and polishing using any good brand name that uses great abrasive technology and you're going to be very happy with the results.
Thanks for all the insight Mr. Phillips!
okay perfect. so in my situation.. do not use the interface and at speed 5.5?
By Indiglofish61 in forum Auto Detailing 101
Last Post: 08-29-2018, 11:12 PM
By john1click in forum Auto Detailing 101
Last Post: 03-27-2017, 05:38 PM
By caudleej in forum Auto Detailing 101
Last Post: 06-21-2016, 01:50 AM
By Loner5777j in forum Auto Detailing 101
Last Post: 04-30-2014, 08:56 AM
By Mirror Detailing in forum Auto Detailing 101
Last Post: 06-10-2010, 02:27 PM
