Results 1 to 7 of 7
    Jun 2012
    115
    Any way to buy 3m Trizact 5000 by the single sheet?
    Hey I'm looking for 5" (or even 6") trizact 5000 grit sand paper by the single pack. I just want to try it before I shell out $85 for a box of paper I might end up having no use for. AG only has the 15 pack available. If anyone is willing to part with 1-3 disks I'll gladly pay $6 each + shipping. I don't know if that sort of thing is allowed on the forums, so please forgive me if it's not. Thanks!
    Aug 2010
    Fairmont, MN
    3,189
    Re: Any way to buy 3m Trizact 5000 by the single sheet?
    PM sent.
    Bill
    Junior Member texasgibby's Avatar
    Apr 2016
    49
    PM sent.
    Super Member g35_coupe's Avatar
    Jul 2010
    413
    Have you tried looking on fleabay? Sometimes they have smaller and larger quantities than what AG carries.
    Mobile headlight restoration in the Oklahoma City area www.okcheadlights.com www.facebook.com/OKC.Headlights
    Jul 2010
    Marietta, GA
    56
    Your local auto parts store will sell single sheets. Check in the painting supply aisle.
    We carry the #3000 Trizact in single packs but I don't see the #5000 on the store.
    On Autogeek.net
    3M Trizact 6 Inch 3000 Grit Performance Sanding Disc 01459 - Singles
    We now have in stock the 3M Trizact 6" #3000 Grit Performance Sanding Disc in single packs from 3M for people that just need to do some spot sanding and don't need an entire box of discs. We also carry the 3" #3000 Grit Performance Sanding Discs for spot sanding minor imperfections of sanding thin panels or working in tight areas.
    All three of these discs are for damsanding, that is they are designed to be used wet, not dry.
    6 Inch 3M #3000 Grit Performance Sanding Disc
    I actually have an article on these single packs...
  1. New Toy - #5000 Grit Trizact Foam Finishing Discs
    Last Post: 11-13-2019, 02:58 PM
  2. Trizact 5000 availability
    By Kdancy in forum Wet-Sanding, Cutting & Buffing
    Last Post: 06-06-2019, 03:28 PM
  3. First time wet sanding kit - #3000 & #5000 Trizact Sanding Discs
    Last Post: 02-03-2017, 08:53 AM
  4. 3™ Trizact™ Foam Discs 5000 FAQs
    Last Post: 11-30-2016, 01:54 PM
  5. Trizact
    By Loner5777j in forum Auto Detailing 101
    Last Post: 04-30-2014, 08:56 AM
