Results 11 to 20 of 22
    Super Member KMdef9's Avatar
    Jan 2014
    The Motorcity
    789
    Re: this carpet has me cornered
    Correct me if I'm wrong, but if those are protein stains, won't OPC set them in?
    You might need ptotein based cleaner. Can't recall what some are ATM.
    Super Member Detailing by M's Avatar
    Mar 2013
    Plano Tex-ass
    998
    Carpets are a dirty filthy beast.
    I get all my carpet cleaning advise from Professional Carpet Cleaners.
    They mostly say not to use heat and most stains won't come out. Do to the fact that they have been set for years and I meen years. They spilled that coffee 5 years ago and they think the stain will come out? No way.
    All you can do is clean it.
    Car Carpet isn't as durable as most people think.
    I only use professional carpet cleaning products and I'm still surprised at what can't be cleaned.
    Find a local Janitorial Supply House and check with them for the right stuff.
  3. #13
    Super Member VP Mark's Avatar
    Jul 2012
    2,451
    Quote Originally Posted by Detailing by M View Post
    I think this is one of the greatest carpet cleaning posts in AGO history. Many people can learn from this. Most stains can NOT be removed, no matter the process or chemicals used.
    Visual Pro Detailing - Auto Detailing near Marion, IL. Call
    (618) 983-9706 www.visualprodetailing.com
  4. #14
    Super Member Eandras's Avatar
    Dec 2011
    Pompton Lakes, NJ
    808
    The first thing I would do is use a stiff brush and brush the stain prior to vaccumming. This will loosen some of the stain from the carpet. Vaccum the carpet and proceed with Folex. Spray it and let it dwell. Get the carpet damp to the touch with the folex. Then agitate with a stiff brush and blot with a white terry cloth towel. This is gonna take time. Steam and extra at the end
  5. #15
    Nov 2014
    Although I don't see the hype everyone is giving folex. I bought some, it worked ok. I gave mine away. I now use prochem liquid slurry, cheaper and works waaaay better. I've had stubborn stains like the OP, and tried APC, Folex, Laundry soap with oxyclean without getting the stain out. I tried those products with an extractor first, then steam after. I had gotten a sample of the prochem from a local cleaner and tried it and it took out 80% the first pass, the rest on the second pass. If you still haven't gotten out the stains(if its your personal vehicle) try the prochem stuff.
  6. #16
    Newbie Member Direct Deposit's Avatar
    Apr 2015
    If you've tried the neutralizing the pH approach, agitated, steamed, swabbed and are not getting results, remove the entire carpet from the vehicle, pretreat and pressure wash it. If somebody Scotch-Garded that stain in, mechanical flushing is the bottom line.
    One interim step you haven't tried is enzyme pretreat and a Tornador. Never seen a carpet that can't be cleaned.
    Hi guys, I'm Keith.
  7. #17
    Aug 2011
    Reisterstown MD
    1,128
    If someone has tried to clean them before the stains may be set and they will not be removed. You may want to try Meguiars takin stain remover
  8. #18
    Mar 2013
    Plano Tex-ass
    998
    Quote Originally Posted by VP Mark View Post
    THANKS! I didn't know how great I am, lol.
  9. #19
    Super Member dcjredline's Avatar
    Mar 2012
    Upstate NY
    3,340
    Yeah I was going to agree with everyone. They are as clean as youre going to get them it seems. Without dye they are done.
    "Dirt likes detergent so much better than the surface that it's attached to, it'll leave that surface to go hang out with the soap"...aim4squirrels
  10. #20
    Super Member AnthonyGXP's Avatar
    Nov 2014
    390
    Rapid remover!
  1. Carpet Cleaning with Drill. What is max rpm to use on carpet?
    By budinthemud in forum Auto Detailing 101
    Last Post: 08-31-2017, 09:31 AM
  2. DA carpet brush on home carpet?
    By Matt@Revive in forum Auto Detailing Tools and Accessories
    Last Post: 04-29-2015, 09:27 AM
  3. I HATE! VW Carpet- Or any carpet that stuff gets inbedded in!
    Last Post: 03-22-2012, 02:06 PM
  4. Carpet Cleaning with DP Carpet Cleaner Question
    By bladerunner in forum Auto Detailing 101
    Last Post: 10-07-2007, 06:03 PM
