Page 1 of 3 123 LastLast
Results 1 to 10 of 23
    Junior Member Vlad's Avatar
    Jan 2016
    Seattle
    82
    Front Plate Holes Bumper Repair
    Hi,
    I'm in the process of fixing up the front bumper holes from the front plate on my 2014 Outback. This will be an ongoing repair and will be updating on it. I may make a video as well. Here is the current situation,
    • License plate holes
    • Haze/chip on the border
    How I am planning to tackle this.
    I have currently ordered bondo bumper repair from amazon, comes with the mesh and epoxy to fill in the holes. I have also ordered spray and touch up paint. I will decide what will be best to fill in the holes. I'll then go over with my polisher (boss g15) to level it all off.
    Jan 2016
    Seattle
    82
    Re: Front Plate Holes Bumper Repair
    Pics
    Attached Thumbnails Attached Thumbnails Front Plate Holes Bumper Repair-front-bumper-holes-ob14-jpg   Front Plate Holes Bumper Repair-haze-front-bumper-ob14-jpg
    Super Member CarolinasFinestDetailing's Avatar
    May 2011
    Charlotte, NC
    1,556
    To be perfectly honest, it will not look factory. As long as you know that, good luck.
    Carolina`s Finest Detailing - Charlotte areas preferred CQuartz Finest Reserve & GTECHNIQ Crystal Serum Ultra coating center. STEK/Suntek PPF
    www.Carolinasfinestdetailing.me
    Jun 2015
    920
    Bumper Plugs .com
    Jan 2016
    Seattle
    82
    Yes, it wont be 100%. I am curious how close I can get to perfection.
    I am not interested in bumper plugs, they don't give a realistic look, imo. I did see other people try them and they seem to like it, depends what you are after.
    I went through the entire thing with Correcting cream and a mf pad, the rest of the border from the paint has gone through the clear and base.
    Attached Thumbnails Attached Thumbnails Front Plate Holes Bumper Repair-polished-haze-ob14-jpg
    Jun 2015
    920
    Good Luck.
    Looking forward to seeing the final result and hearing the details of the process.
    Oct 2015
    409
    Good luck!
    I don't think you will need the mesh. I'd try it without first.
    Is the touch up paint the exact same color? Red can be one of those that stands out if it isn't the exact same.
    Jan 2016
    Seattle
    82
    Quote Originally Posted by craigdt View Post
    Good luck!
    Really no mesh? But bondo is needed no question. The mesh is there for it to form/dry on, my thinking was to put the mesh behind the bumper.
    I did order exact color code. I bought the paint in the touch up bottle AND the aerosol (and clear coat in both forms as well). I am wondering what would be best to use to fix the paint. There are lots of little chips around where the plate perimeter was, they have gone through the base as it appears. While I do have the patience to go by them one by one, I'm not sure if it will be better than to just spray paint it by using the blending technique.
    Jun 2015
    920
    I hope you didn't buy the non-2k clear from Automotive Touch-up Paint . Com
    It is a disaster
  10. #10
    Jan 2016
    Seattle
    82
    Quote Originally Posted by AGOatemywallet View Post
    It is a disaster
    I almost bought the 2k clear coat from Automotive touch up paint. It got so expensive with everything, so I took it and the air mask out. They have still not shipped the order, maybe I can cancel by calling. Whats wrong with the "normal" clear coat they have? I'm calling them right now to cancel then and replace it with the 2k... But what about the touch up clear coat in a bottle?
    *Update* I just called and canceled the normal clear coat and replaced it with the 2k one and added the air mask.
  1. Front bumper rash repair before clear bra?
    By Sorang06 in forum Auto Detailing 101
    Last Post: 06-25-2020, 04:54 PM
  2. Front Bumper Lip Help
    By ihrkthejerk in forum Auto Detailing 101
    Last Post: 06-07-2018, 02:30 PM
  3. Protect the front bumper from license plate/frame/etc
    By captainbeach in forum Ask your detailing questions!
    Last Post: 11-23-2013, 09:22 AM
  4. Wet Sand Front Bumper?
    By kevinmcc in forum Wet-Sanding, Cutting & Buffing
    Last Post: 08-21-2013, 09:31 AM
  5. Different LSP on front bumper
    By aray in forum Auto Detailing 101
    Last Post: 08-25-2012, 12:02 PM
» March 2024
2526272829 1 2
3 4 5 6 7 8 9
10 11 12 13 14 15 16
17 18 19 20 21 22 23
24 25 26 27 28 29 30
31 123456
