» Detailing Classes
Page 3 of 3 FirstFirst 123
Results 21 to 24 of 24
  1. #21
    Senior Member Calendyr's Avatar
    Jun 2013
    Montreal, Quebec
    3,893
    Re: Gas pedal cleaning
    I tried using a soft bristle bush, it did improve it a bit but did not get is clean. I tend used my tire cleaner (Meguiars non-acid wheel cleaner) with the soft bristle brush, did not see much change.
    I watched a video today where the guy used Griot's Garage Rubber cleaner to clean a tire and the result was pretty impressive. I might have to try with a rubber cleaner and see if it solves the issue for me.
    Maybe it's salt that is stuck to the rubber... we do have tons of it in the winter here in Montreal... I have tried my salt removal spray on the pedals before and it did not much.
    I don't want to use a steamer, it's too much of a pain. I know I have used it years ago to do it and it was ok... I can't remember if it did a better job than an actual cleaner with a brush, but I would doubt it.
    The search continues
  2. #22
    Senior Member pro 4x's Avatar
    Mar 2011
    PA
    4,213
    Yea. Thought I was the only one that cleaned my pedals! LOL. Never really had a issue. I just hit them with some APC and use a brush or towel to get them clean.
    2018 Colorado ZR2
    http://www.autogeek.net/
  3. Likes PaulMys liked this post
  4. #23
    Oct 2019
    Personally, I've used the Tornador detail tool + degreaser + scrub brush + microfiber to wipe and that has produced great results on thousands on customer vehicles. (Keep in mind NOT to apply any chemical to the pedals that could cause them to remain slippery after clean, that's a BIG safety issue.)
  5. #24
    Senior Member UncleDavy's Avatar
    Aug 2017
    Taunton, MA
    985
    A couple of methods have worked for me. I have used Megs D103 diluted 1:1 and LATA diluted 1:1. Both cleaners were effective but what made the difference for me was the brush. I used a tooth brush to get in all of the grooves and it worked well. Then I gave it a spray of just plain water for a rinse. It was time consuming and the wife thought I reached a new level of crazy but it worked quite well.
  1. Must Have Wheel Cleaning Brushes that make cleaning wheels fast and easy
    By Mike Phillips in forum How to articles by Mike Phillips
    Last Post: 12-30-2019, 03:50 PM
  2. Washing and cleaning Compound and Polish Self-Cleaning Caps
    By Mike Phillips in forum Ask Mike Phillips your detailing questions!
    Last Post: 09-04-2019, 03:40 PM
  3. Dead pedal corrosion
    By jpik in forum Auto Detailing 101
    Last Post: 03-23-2019, 03:27 PM
  4. Cleaning wax/sealant out of foam pads with the Grit Guard Cleaning bucket?
    By TotalNewbie in forum Wool & Foam Buffing Pads
    Last Post: 05-29-2013, 08:43 PM
  5. foot pedal
    By Ford2000 in forum Auto Detailing 101
    Last Post: 05-03-2012, 08:27 PM
Members who have read this thread: 72
» January 2020
293031 1 2 3 4
