» Detailing Classes
Results 11 to 20 of 24
    Senior Member Calendyr's Avatar
    Jun 2013
    Montreal, Quebec
    3,907
    Re: Gas pedal cleaning
    If it's a rubber pedal cover. Why not try the Tuf Shine Tire Cleaner or any other rubber cleaner.
    I have found a rubber and plastic protection that is not sold on AGO sadly. But awesome to use on floor mats and pedals and even in the engine compartment like Megs Hyper Dressing and those you spray on when it's wet there and just leave it to dry over night. Maybe the Wheathertech cleaner and protectant could work on the pedals too if it don't leave it slippery.
    And some pedals is just bad quality and it goes fast for them to wear down and don't looks so good then. There is a way to get the rubber rubbed up. But it works just on those that is more like a tires finish and not those that is more on the plastic side. Or look up how much a new pedal cover would cost. It's a big risk to do this restoration on a customers car. But on your own vehical it can extend the life and looks from it and you know of the risk it can go bad.
    Don't have any of those products unfortunatelly. I would be wary of putting a dressing on the pedals. Maybe I am just paranoid but even a water based dressing like Meg's hyperdressing would probably become slipery if the client walks in the rain and the used the pedals. I have seen people using Solution finish on pedals and they look awesome afterwards.... but I am not too trilled about going about doing that. Took much risk of staining the carpet unless you take crazy precaution to cover the whole thing first. I just want them clean, no need for them to look new
    Jun 2013
    Montreal, Quebec
    3,907
    I clean ‘rubber’ pedals with Meguiar’s M39...
    along with (depends on how soiled they are),
    any one of the following type/style of brushes:
    (Who remembers Meguiar’s X1000 brush?)
    My pad brush is full of compound and polish I don't think it would do a good job. Also the shape of it would make it hard to work on the pedals... no?
  3. #13
    Senior Member FUNX650's Avatar
    Dec 2010
    Ohio, USA
    20,469
    Quote Originally Posted by Calendyr View Post
    I have a dedicated cleaning-the-pedals
    pad cleaning brush.
    As an adjunct:
    Surely no one in their right mind would
    ever use it for cleaning pedals—if it was,
    indeed, previously used to clean pads...amiright?
    And:
    I do find its shape to be, ergonomically speaking:
    very satisfactory for quite a few vehicles’ pedals.
  4. #14
    Senior Member AutowerxDetailing's Avatar
    Apr 2012
    Sherwood, Oregon
    2,782
    I generally clean pedals with APC, a soft, round brush, and then rinse clean with the steamer to clean out all the tiny grooves.
    Nicholas Scafidi - CQuartz Finest Authorized Installer
    www.autowerxdetailing.com Auto Detailing in Sherwood, OR
    Like us on Facebook | Follow us on Twitter
  5. Thanks Diner thanked for this post
  6. #15
    Apr 2016
    Toronto, Canada
    307
    I use a brush like this and OPC. The bristles are soft, but very densely packed.
    Large Multi-Purpose Brush
  7. Thanks Diner thanked for this post
    Likes AutowerxDetailing liked this post
  8. #16
    Apr 2012
    Sherwood, Oregon
    2,782
    That's exactly what we use. Works great for getting into all the tight little grooves on most pedals.
  9. #17
    Apr 2018
    I use the same brush. If I need more stiff bristles I just grab them with my fingers and bunch them up to the necessary firmness. Did I learn that from Mike?.....not sure, I’ve learned so much here.
  10. #18
    Jun 2013
    Montreal, Quebec
    3,907
    pad cleaning brush.
    As an adjunct:
    And:
    Ok. Might give it a try then. I rarelly use that brush anymore, unless I am cleaning a microfiber cutting pad. Still have to try the soft brush and see how that goes.
    No interior detail booked this week, so I will have to be patient
  11. #19
    Jun 2019
    110
    I just use my steamer and an mf towel
  12. #20
    Senior Member Paul A.'s Avatar
    Dec 2007
    Tampa Florida
    4,740
    I use my M37 blower to blow them dry after cleaning with APC and a softer bristled brush. The blower seems to dry out the recesses of the pedal. MF towels can't seem to get in there.
  1. Must Have Wheel Cleaning Brushes that make cleaning wheels fast and easy
    By Mike Phillips in forum How to articles by Mike Phillips
    Last Post: 04-15-2020, 11:33 AM
  2. Washing and cleaning Compound and Polish Self-Cleaning Caps
    By Mike Phillips in forum Ask Mike Phillips your detailing questions!
    Last Post: 09-04-2019, 03:40 PM
  3. Dead pedal corrosion
    By jpik in forum Auto Detailing 101
    Last Post: 03-23-2019, 03:27 PM
  4. Cleaning wax/sealant out of foam pads with the Grit Guard Cleaning bucket?
    By TotalNewbie in forum Wool & Foam Buffing Pads
    Last Post: 05-29-2013, 08:43 PM
  5. foot pedal
    By Ford2000 in forum Auto Detailing 101
    Last Post: 05-03-2012, 08:27 PM
Members who have read this thread: 25
» July 2020
