» Detailing Classes
Page 3 of 3 FirstFirst 123
Results 21 to 27 of 27
  1. #21
    Feb 2015
    Ft. Lauderdale,Fl
    568
    Re: Regular wax on rims. ??
    I coated my wheels a year ago. Still shed water and clean easily. Bit time consuming but worth it to me. Canít mention it since itís not sold at AG but Iím sure some of the ones they carry will do the same job.
  2. #22
    Senior Member Coatingsarecrack's Avatar
    Dec 2018
    1,337
    Agree. Coating is the way to go. I've coated a couple sets of wheels and it makes them much easier to clean.
    You can't find them at AG, but at least one coating vendor who sells coatings here offers 10ml sample sized bottles for sale elsewhere. It's the perfect size for doing a set (or two) of wheels.
    AutoGeek has c5 wheel armor (Gtechnic) in 15ml bottle. Havenít used mine yet but got good reviews from most
  3. #23
    Oct 2019
    I've used Gtechniq C5 Wheel Armour and it has held up to the toughest and longest Canadian winter we had last year (Mid Nov to April)! Thought we'd get a break this year, snow on the ground this morning!
  4. Likes Coatingsarecrack liked this post
  5. #24
    Senior Member Rsurfer's Avatar
    Jan 2007
    12,070
    Quote Originally Posted by carcarecoaches View Post
    And it's not even mid November..I feel for you way up north.
  6. #25
    Member Eric7810's Avatar
    Mar 2019
    40
    Michigan here, itís terrible.
    My car currently sits in the garage with dried salt water on it. Most people with nice hobby cars only have them out five months before itís time to hang them back up in storage.
  7. #26
    Sep 2017
    Sweden
    2,838
    Quote Originally Posted by wantboost View Post
    Any idea how to remove these stains from the previous liquid wax ??
    If it's just wax. Spray some APC on it after you have cleaned them and let it dwell and aggitate it lightly and rinse off directly. Don't let chemicals dry on and surface and you will be fine. If you have an acidic based wheel cleaner you can start with that and after a thoroughly rinse. You can apply an alkaline based wheel cleaner. With aggitations you make it more effective. And think that this would be takeing off the old wax.
    If this don't work you probebly have a chemical etching which is needed to be polishing. Test with the least aggressive first as a polish and move up if necessary to a compound. If you are unlucky and the chemical etching has gone through the paint on the rims. The aluminum is porous and it's gone deep inside of it. So it's only to be repaint them to sort it out.
    You can in between the cleaning heat it up and see if it's coming back. A hairdryer is usually enough and if you know what you are doing and are carefull a heat gun will also work. If you get it back you may need to be doing a couple of these cleaning. Just don't heat up and of the new chemicals you have put on.
  8. #27
    Senior Member Desertnate's Avatar
    Aug 2013
    St Louis metro (Illinois)
    3,853
    I was referring to CQuartz UK. The sample bottle is much less than Gtechnic, yet still has enough to do a second coat or a coat on another set of wheels.
    CQUK on my last set of wheels easily lasted two years. Not bad durability in my mind.
  9. Likes Coatingsarecrack liked this post
  1. Should I thoroughly clean a customer's rims in a $20 regular wash?
    By JICs Auto Detail in forum Auto Detailing 101
    Last Post: 05-11-2018, 08:43 AM
  2. Replies: 7
    Last Post: 04-14-2015, 07:13 AM
  3. Woolite instead of a regular APC?
    By fellipe in forum Auto Detailing 101
    Last Post: 08-29-2014, 10:09 AM
  4. Black car wax vs regular carnauba
    By Greg5OH in forum Auto Detailing 101
    Last Post: 12-06-2013, 12:16 PM
  5. Wave vs. Regular
    By Excessive Detail in forum Porter Cable 7424XP Dual Action Orbital Polisher
    Last Post: 06-11-2007, 07:39 PM
Members who have read this thread: 109
» November 2019
2728293031 1 2
3 4 5 6 7 8 9
10 11 12 13 14 15 16
17 18 19 20 21 22 23
24 25 26 27 28 29 30
