Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
    Apr 2012
    7,494
    Re: looking for a wax to pad tip
    I use a small butter knife, a small putty knife works too, but the butter knife is rounded and you can get into the round container more easily. So you butter the pad just like a piece of bread, nice and thin.
    2019 Nissan Rogue SL
    Jan 2016
    462
    thanks guy's. using a butter knife or credit card sounds like a good idea. that'll be a good way to keep my hands clean.
    hmardown
  3. #13
    Jul 2016
    3,328
    Quote Originally Posted by hmardown View Post
    hmardown
    I don't understand why you need to add utensil into the process what's so hard about scrunching up a foam pad I do it that way all the time
  4. #14
    Nov 2015
    Los Angeles, California
    13,752
    Quote Originally Posted by fightnews View Post
    Because it’ll be easier to get even coverage with a credit card or a butter knife. Scrunching the pad into the can will leave you with clumps around the edge.
  5. Likes custmsprty liked this post
  6. #15
    Aug 2013
    Tustin, CA
    4,389
    I use a 3" Pad and it fits perfectly in MOST jars of wax. I use my PC7424XP as my wax applicator. I just put the pad in the jar of wax and I EITHER blip the trigger or move the Pad back and forth manually. No need for a knife, credit card or scraping. At least this is what I do.
    If the pad does not fit in the jar I just take the pad off and squeeze the pad to fit or just use the pad to grab some wax and then put it back on the DA. So far, this has worked for me. No need for gloves or tools to worry about.
    CJ
    Save the Manual!
