Results 11 to 20 of 21
    Senior Member Calendyr's Avatar
    Jun 2013
    Montreal, Quebec
    2,607
    Re: Some silly issues I need advice on
    Ya, doing 15 rounds of cleaning to apply a coating is not something I can realisticly offer to a client. You are talking of about 45 minutes work to prep each tire, I would need to charge like 3-4 hours work to do it. Would you pay 120-160$ to coat your tires? I sure wouldn't!
    So no one has an actual sure way to remove Armor All in a reasonable amount of time (say 5-10 mins per wheel)? I could try gasoline next time the issue shows up, I just don't know how effective it would be. Other than that only other hard solvents I can think of are the typical Acetone, Paint Thinner and Grease and Wax remover (Duplicolor). I doubt those would work since I don't think any of them are petrolium based.
    Senior Member Audios S6's Avatar
    Oct 2011
    Shoreview, MN
    1,609
    Wax and grease remover, silicone remover, tarminator; or in my case, I have use Kleen strip prep-all successfully.
    Do not use gasoline; it will leave substantial residue that could affect the tire and will just be more of a pain to remove; consider how carburetors can gum up.
    Static & Mobile detailing in Minneapolis & St. Paul. http://www.detailedcreationsmpls.com/
  3. #13
    Senior Member Dr Oldz's Avatar
    Aug 2010
    NE PA
    3,137
    If you can find a product called Whitewall Cleaner by Trans-mate. It's all I use for tires. It will take any dressing/bloom from tires. Not sure the chemical compound in it but I have been using it for over 20 years with amazing results.
    Jim
  4. #14
    Senior Member Mad Wax's Avatar
    Sep 2014
    290
    I've heard somewhere on here Tarminator strips everything off tires. I have not yet tried it though.
  5. #15
    Senior Member Eldorado2k's Avatar
    Nov 2015
    Los Angeles, California
    6,967
    Quote Originally Posted by Mad Wax View Post
    I know a detailer who swears by Tar X. I think it's too expensive to be using as a tire cleaner.
  6. #16
    Nov 2015
    6,967
    Quote Originally Posted by Calendyr View Post
    1) Removing Armor All from tires. Anyone know an effective way of doing it? Last detail I did, the client wanted a wheel coating. He has been putting Armor All on his tires for years.
    Which exact Armor All tire product do you think he had been using? There's quite a few...
  7. #17
    Apr 2013
    965
    Brush on a PC with some mineral spirits and or tarminator
    I still wouldn't guarantee the coating. I would just use a quality tire gel at this point and say maybe your next tires we can coat if you don't use that stuff again
  8. #18
    Jun 2013
    Montreal, Quebec
    2,607
    Has to be the basic original formula. Around here, that is the standard stuff from Armor All. The rest are specialized products not designed for tires.
  9. #19
    Jun 2013
    Montreal, Quebec
    2,607
    I don't have Terminator. I do have Tar-X and yes it is quite an expensive product. I could give it a try next time around to see how it does. I am pretty sure the product is pine oil based, from the smell. So if pine oil works well, I could try pine based cleaners and see how they perform. Something like pine sol or even turpentine. That is a good lead to pursue. Thanks.
  10. #20
    Jul 2017
    In cases like this I've had great success using Goop hand cleaner, the original one. Tire has to be dry. I smear it around then wipe off with disposable cloths (not paper towels). It can be messy if you're not careful but it works. Then follow up with a quality degreaser, per usual . The process is not cost efficient but is probably less costly than 15x per tire.
  1. silly question....
    By tunakiller in forum Auto Detailing 101
    Last Post: 07-04-2014, 12:46 AM
  2. Silly Question....
    By Sixbanger in forum Ask Mike Phillips your detailing questions!
    Last Post: 01-10-2014, 04:45 PM
  3. Employment issues - any and all advice welcome!
    By Bates Detailing in forum Off-Topic
    Last Post: 05-02-2012, 09:18 PM
  4. DG AquaWax....Silly me!
    By A.P.A.D. in forum Auto Detailing 101
    Last Post: 08-09-2011, 09:16 PM
  5. This is so silly...
    By P1et in forum Off-Topic
    Last Post: 05-10-2007, 08:25 AM
