Re: Struggle with white paint..ugh
Originally Posted by
idriveblackcars
But I couldn't even see a line of product
I put on the car. It went invisible the second
it was on the paint. I didn't know where to
wipe or where I left off lol.
"A line of product" just creates another
type of "paint condition".
The same lighting principles that I
mentioned earlier still apply, IMO.
FUNX650
I guess that is true.
In the case of white or light colored paint, the lighting of the environment in which you're detailing is so important. We use headlamps if necessary!
I would suggest headlamps as well. I don't polish without them, and I definitely don't coat without them either. I also have a LED flashlight that you can put down on the ground and aim the head that I use as well. Other thing about white cars, might be just me but does it seem that white is generally a harder paint?
Machine polish or wax application instead of hand application
Wipe off residue
Go over car again with a quick detailer or spray wax
I think that should work for not missing a spot on white paint, even with poor lighting.
A black light might help.
I've found I have to set a section before I start, then I know where that polish is and can wipe it off. Make another section etc etc. Like I'll go from a door handle edge (the rear of it) and leave one foot planted for the other"edge" of my section. Then I know I gotta wipe between the door handle and my leg.
"Dirt likes detergent so much better than the surface that it's attached to, it'll leave that surface to go hang out with the soap"...
aim4squirrels
My last couple cars have white. When polishing, I like to use little bits of the green tape to mark boundaries of polishing areas. With my grid pointers I know what I have done. Sealants and lsp's are still a challenge though. Real slow final wipe with a plush towel can help you feel any difference in the surface condition such as remaining product. No perfect solution though.
