Results 11 to 20 of 24
    Super Member spazzz's Avatar
    Jan 2014
    Madison
    1,013
    Re: Winter Road Salt
    Quote Originally Posted by fightnews View Post
    what are you using for a salt emulsifier? take the car to the coin op pressure washer to do the heavy stuff and the wheel wells before doing the waterless thats what i do, next time i might just bring the waterless to the coin op place and wipe it down quick right there
    I use Salt-Away. Dapper Dan recommended it last year and I picked some up.
    64oz for $40some. 2oz to a gallon in a pump sprayer. Yep
  2. Likes HOTSHOTS liked this post
  3. #12
    Jul 2017
    I use a similar technique. I mix Meg's Gold Class real heavy in a spray bottle then generously spray the whole vehicle. By the time I'm done, the salt and soap have become one and I use a garden hose to spray it, alternating between light misting, heavy spray, cascading water. Then wash by hand as usual.
    This system works and start to finish takes less time than dragging out the pressure washer, setting up the soap mixture for foaming, foaming, pressure washing all of it off, then draining these hose and putting away the pressure washer. Then wash by hand.
  4. #13
    Super Member UncleDavy's Avatar
    Aug 2017
    Taunton, MA
    1,586
    Hey Jet. What is the mixture ratio for your Meguiars Gold Class? I am always concerned about salt on the vehicles in the winter. I can actually hear it eating the paint.
  5. #14
    Jan 2015
    Amherst, NY
    156
    It's still September. Can we not worry about road salt till December or so? Winter is long enough. But anyway, I'm lucky to find a coin wash still open around here after it gets below 25F or so. Pre soak in the garage with RW in a pump sprayer, then do a rinse less using either a lot of towels or rinsing the BRS out often
  6. #15
    Jul 2016
    3,328
    Quote Originally Posted by VeloNYC View Post
    And it cost $5 to wash the salt and dirt off, and ˘20 to bring a gallon (diluted in my case D114) waterless wash solution.
    So it's 5 dollars? That's pocket change who cares
  7. #16
    Jul 2016
    3,328
    Quote Originally Posted by boomdone View Post
    Whip's Wax. Hopefully PBMG will carry it one day. Doesn't harm your LSP. Sometimes I'll go to the coin op and spray it with WW then pressure wash clean. Then I'll go home and do RW in my garage with all the salt off my car.
    Are you positive it doesn't hurt the lsp I've heard that before and have been burned
  8. #17
    Jul 2016
    3,328
    Quote Originally Posted by kevincwelch View Post
    I've been eyeballing that road salt remover.
    I basically do your routine - blast the car at the coin op and then take it home for the presoak and then RW. I can't say -- in my experience -- that not using a road salt remover is unsafe. I've been blasting my car at the coin op and doing the presoak/RW for a few years now and haven't noticed any swirling doing this. I have been using 840-1100 GSM towels and basically doing a single wipe with a single quarter on my DD. I use a lot of towels, but I think it saves the paint.
    Wow that's dedication. I do the "fold back" method that people do with a waterless wash. I feel like 1 wipe per quarter would be excessive evn though I have more towels then I could ever use
    Quote Originally Posted by spazzz View Post
    Is that lsp safe?
  9. #18
    Super Member Stittville Ed's Avatar
    Mar 2006
    Stittville, New York
    349
    I'm very Lucky to have a Power Washer and when I re-plumbed my house as my rehab from a Hernia operation I ran a Hot water outside right where I wash all the cars.
    Works out very well for me.
    In Upstate NY the ice and snow has not been letting up all winter.
    I took the mats out of my Wife's car and put them in the washing machine.
    I did a extra rinse and after I took them out I wiped the drum out and ran another wash cycle to make sure the washer was clean.
  10. #19
    Newbie Member tryn2shine's Avatar
    Nov 2017
    Juhryzee shauw. but an ol Flatbush boy @ heart
    Quote Originally Posted by Stittville Ed View Post
    You're a VERY brave man, my wife would give me a whoopin if I dragged car mats into the house, forget the washing machine but I oblige her concerns by doing my MF's & car towels in a separate wash. No brake dust rags or greasy rags ever go into the WM, I don't like that myself, plus we have septic system so the less chems in there the better.
  11. #20
    Sep 2017
    Sweden
    3,022
    If you go to a coin op or have the ability to PW or hose at home. Test with Optimum Power Clean and spray the car with and let it dwell. Use the water pressure from the PW or hose to clean rinse the car from bottom up and then rinse down again. To use the OPC the most. Diluted 1:3 it has a good value I think. And if you are satisfied with the results buy the gallon of it. To make it a little easier and faster to spray. Buy a pressure spray bottle and have it 1:3 dilution and the original spray bottle with undiluted to the wheels and wells. You could buy a kwazar double sprayer bottle to make it fast also. Then drive home or do it by the coin op if possible and rinseless wash. There is citrus based degreasers that are powerfull and 3D and britemax has some that I think would work also.
    Optimum Power Clean All Purpose Cleaner 17 oz.
  1. Washing winter road salt off the car!
    By BF4Noob73 in forum Auto Detailing 101
    Last Post: 01-28-2016, 08:25 PM
  2. ONR & Road Salt
    By Nth Degree in forum Auto Detailing 101
    Last Post: 01-26-2016, 01:57 PM
  3. Road Salt
    By stateguy in forum Auto Detailing 101
    Last Post: 02-08-2015, 12:17 PM
  4. Getting winter road salt out of cloth floor mats
    By -Longhorn- in forum Auto Detailing 101
    Last Post: 03-17-2010, 12:42 AM
  5. How to clean road salt......
    By blckbrd in forum Auto Detailing 101
    Last Post: 02-26-2007, 11:20 AM
