Mixing APC
I've been doing this for a while and I thought I'd share it. When I mix my go-to APC's (Zep Citrus, 505 and LA Totally Awesome), I don't mix them with water. I mix them with the soapy water mix I'm going to wash the car with. It doesn't negatively affect the performance obviously and if anything, I find it makes them perform a bit better.
Re: Mixing APC
Interesting to know... I usually dilute w/ distilled water.
Re: Mixing APC
Ive tried that with red hot,seems it creates quick run off deosnt cling to a surface that well.
Re: Mixing APC
Ok. Works for me with the APC's I use
Sent from my E6853 using Tapatalk
Re: Mixing APC
Reminded me of this from a few years back.
https://www.youtube.com/watch?v=WUGU...ature=youtu.be
I've had one bad episode with APC+ 20:1 and one bad episode with OPC 10:1 ... water/apc. Both did NOT dry on the paint and were rinsed thoroughly and both left bad stains on the paint, sand colored and black. Both were sprayed onto wet paint from a pre-mixed dilution from a spray bottle. Naturally, I'm a little gun shy. I have not tried the apc's that you use though.
I take it you're mixing in a bucket like in the above video? I would be more comfortable mixing apc this way with the wash soap than direct spraying onto wet paint.
Re: Mixing APC
I like that idea, Richy. I am going to try it with an engine detail later.
Re: Mixing APC
Wow, Garry Dean really turned that car around!!
Re: Mixing APC
Richy,
I'm going to assume you typically only use one type/brand of soap? If so, then are you putting your soap solution into bottles and then mixing it with your apc's and using it that way? I had trouble picturing in my mind exactly how you were using these and that's what brought the Garry Dean video to mind.
Re: Mixing APC
Sorry guys if I didn't take the time to properly explain what I meant. Instead of taking my spray bottle with APC and adding tap water and then more APC (when it needs refilling), I am taking the almost empty bottle and submerging it in my wash bucket and adding my Megs Hyper Wash soap mix into the bottle and then topping it up with the appropriate amount of APC (4:1 or whatever). Hope that makes it more clear. Sorry for any confusion.
Re: Mixing APC
Lolz. I love GD - but it's funny watching him clean wheels with a toilet brush.
By HUMP DIESEL in forum Auto Detailing 101
Last Post: 03-18-2014, 08:29 AM
By FPEvo in forum Tricks, Tips and Techniques
Last Post: 05-21-2012, 05:14 PM
By MoBenzOwner in forum Auto Detailing 101
Last Post: 05-04-2008, 12:45 PM
By ricka in forum Auto Detailing 101
Last Post: 08-12-2007, 07:00 AM
By ltoman in forum Auto Detailing 101
Last Post: 12-06-2006, 12:55 PM
