Thanks Thanks:  0
Likes Likes:  0
Dislikes Dislikes:  0
Page 2 of 5 FirstFirst 12345 LastLast
Results 11 to 20 of 45
  1. #11
    Super Member
    Join Date
    Sep 2015
    Posts
    6,281
    Post Thanks / Like
    Re: More aggressive compound or pad?
    I know your starting out ,a rotary would be a option for a perfect finish .Da has limitations don't get me wrong a da can give u awesome results.i was never a da guy till mike Phillips introduced all kinds of da machines.now I use them everyday ,I like to keep things simple and clean no swirls and most of all no product sling.applying wax is so simple with a da. I encourage anyone thinking of getting one the meguairs gv110 is nice and light doesn't get hot and minimum vibrations.I had to wet sand 20000 square foot wood floors and it never let me down.
  2. #12
    Super Member Joe@NextLevelDetail's Avatar
    Join Date
    Jun 2015
    Posts
    1,929
    Post Thanks / Like
    Never jump to polish and hope that they will come out in that step.
    do a few more section passes. and get the swirls out.
    also if you see little circular swirls, that could be from your compound, do not try to chase those out with compound ,as that is what is causing those marks in the first place.
    the polish will get those out!
    compound is nothing without polish and polish is nothing without compound.
    they really are the Jordan and Scottie Pippen tag team!
  3. #13
    Junior Member
    Join Date
    Apr 2010
    Location
    Littleton, CO
    Posts
    49
    Post Thanks / Like
    Quote Originally Posted by NextLevelDtail View Post
    No circular swirls, so I'm not making it worse. I will do the hood again.
    Bright Red 2006 BMW Z4 3.0si roadster. Crystal Black Pearl 2011 Honda Odyssey EX-L
  4. #14
    Super Member Paul A.'s Avatar
    Join Date
    Dec 2007
    Location
    Tampa Florida
    Posts
    5,274
    Post Thanks / Like
    Its great to hear a little more pressure is doing the trick for you! And be comforted knowing you are only removing enough surface paint to level down those scratches...and not more than you need to. Also, you are the judge as to what you want the finished results to look like. WG glaze is an amazing product and i can say that from use however if after trying it on a test section you don't like the appearance of it, by all means, stop.
  5. #15
    Junior Member
    Join Date
    Apr 2010
    Location
    Littleton, CO
    Posts
    49
    Post Thanks / Like
    Today, I did the drivers side. It did take two sets of passes. I had to do a section over the rear wheel three times. It looks great!
    Again, I used the WG glaze on the front fender. And again, it looked a little cloudy. Not much, but noticeable to me. I wonder if I'm not working it long enough.
    I then finished it with Pinnacle wax.
    Since I have some Meg's 205, I try that when I do the other side of the car.
  6. #16
    Join Date
    Dec 2007
    Location
    Tampa Florida
    Posts
    5,274
    Post Thanks / Like
    I have worked WG Fnishing Glaze almost the same as i work Menz 4000 or 4500...LONG and on either a white LC flat pad or, for softer paints, a black or red pad. I work it until almost invisible and sometimes i get that rainbow like affect on my black paint. Wipe off is easy and it leaves a beautiful finish. When i say long i mean, for me, maybe 8 section passes after spreading it out. And lighten up on the last pass or two.
    Maybe work it longer and see if it makes a difference to you.
  7. #17
    Junior Member
    Join Date
    Apr 2010
    Location
    Littleton, CO
    Posts
    49
    Post Thanks / Like
    Yesterday, I polished the passenger side of the car. Today, I did the hood for the second time.
    This time, I finished using the WG glaze with a blue pad. I worked it a lot longer than I had before. That was the difference from the first time that I used it. After finishing the hood today, I had to go back and do the trunk lid with the glaze.
    Now all I have left to do is the front and back end. Along with the rocker panels.
  8. #18
    Junior Member
    Join Date
    Sep 2014
    Posts
    50
    Post Thanks / Like
    It sounds like you are going to end up with a very nice looking car.
    I am new to this too and I polished my car months ago and it looked better.
    Then I polished it a couple weeks ago using the same pinnacle polishes and pads and polisher I used months ago, and wow the second polishing really cleaned up the left over swirls and minor scuffs on the surface.
    So I agree that additional passes will for sure keep improving a surface, but having the experience/knowledge to know how much pressure to use and what speed to run the machine at is needed too.
  9. #19
    Junior Member
    Join Date
    Apr 2010
    Location
    Littleton, CO
    Posts
    49
    Post Thanks / Like
    Yes, it does look good! At least as good as when I purchased it new in early 2007. So far, I done 2 sets of passes on what I've done because one didn't do it. I started to get concerned that I'd run out of polish. While it's not perfect, it's not worth more passes.
  10. #20
    Super Member Klasse Act's Avatar
    Join Date
    Feb 2012
    Location
    Palatine Illinois, USA
    Posts
    24,526
    Post Thanks / Like
    I know there's vids here as well as YouTube. Griot's has easy to understand and entertaining vids, check em' out.
    What machine are you using, maybe the speed is a bit too low but one things for sure, watch the vids, pick up some pointers and you'll get it, trust me/us.
    2022 Elantra N Cyber Gray
    Some say..."He likes Swedish fish because they're made with caranuba wax"
Similar Threads
  1. Which more aggressive compound/polish might I need
    By AJ Peacock in forum Auto Detailing 101
    Last Post: 03-22-2017, 05:31 PM
  2. More aggressive pad? Or more aggressive compound?
    By tone357 in forum Auto Detailing 101
    Last Post: 12-28-2015, 10:17 PM
  3. Replies: 4
    Last Post: 08-02-2013, 08:28 PM
  4. POLL: More Aggressive Compound OR Pad?
    By waldron80 in forum Auto Detailing 101
    Last Post: 03-26-2008, 05:15 PM
  5. Replies: 0
    Last Post: 06-01-2006, 01:21 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
» April 2024
S M T W T F S
31 1 2 3 4 5 6
7 8 9 10 11 12 13
14 15 16 17 18 19 20
21 22 23 24 25 26 27
28 29 30 1234
