Thanks Thanks:  0
Likes Likes:  0
Dislikes Dislikes:  0
Results 1 to 3 of 3
  1. #1
    Super Member dlc95's Avatar
    Join Date
    May 2013
    Location
    Rochester Hills, Mi
    Posts
    6,016
    Post Thanks / Like
    Rupes Shroud Grease
    When cleaning the Duetto, I ended up removing all the grease that was around the inside of the shroud.
    Is there a recommended type of replacement?
  2. #2
    Mike Phillips
    Guest
    Re: Rupes Shroud Grease
    Quote Originally Posted by dlc95 View Post
    I think that's just sling from the internal gears escaping past the seals. Not enough to worry about in my book.
    If there was an excessive amount of grease inside the shroud then I would look for the root cause of the problem.
  3. #3
    Join Date
    May 2013
    Location
    Rochester Hills, Mi
    Posts
    6,016
    Post Thanks / Like
    Nope, just a very light residue. Thanks Mike! That's all I needed to know!
Similar Threads
  1. How to lubricate the shroud on long stroke polishers
    By Mike Phillips in forum How to articles
    Last Post: 04-17-2019, 02:13 PM
  2. Grease a new G6 or G3 before first use?
    By Thomkirby in forum Griot’s Garage Polishers - BOSS - 6" DA - 3" DA
    Last Post: 08-20-2018, 07:56 PM
  3. Grease in rupes mark2?
    By Indiglofish61 in forum Auto Detailing 101
    Last Post: 08-16-2018, 09:31 PM
  4. Rupes Mini And The Missing Anti-Spin Shroud
    By dlc95 in forum RUPES BigFoot Oribital Polishers
    Last Post: 10-12-2017, 08:02 AM
  5. Replies: 29
    Last Post: 05-21-2016, 07:46 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
» April 2024
S M T W T F S
31 1 2 3 4 5 6
7 8 9 10 11 12 13
14 15 16 17 18 19 20
21 22 23 24 25 26 27
28 29 30 1234
