Dislikes: 0
Re: Meguiars ultimate compound vs clear coat safe rubbing compound
UC is a rubbing compound. And is safe. As are all auto compounds.
With all rubbing compounds you have to use a less abrasive polish after. Regardless of how smart their abrasives are or how much they diminish. There is no "shortcut".
But I cannot comment on your pictures because I can't tell what specifically I'm looking for. Maybe someone else.
Super Member
As you probably already know, working by hand is quite a task in itself if you don't have access to a machine. From my experience 3M Compound will leave it's own damage/scratches behind that you'll need to follow with a less aggressive polish to achieve a perfect finish. Ultimate Compound on the other hand is pretty good at finishing wax ready if worked properly, or can be used to follow up after the 3m. However, neither of these products will be able to level the area pictured completely due to the amount of touch-up that has been applied.
My goal is to not so much to level it anymore at this point. Rather increase the shine of the touched up area and remove the haze/swirl marks around it (hard to tell from pics).
Again, I'm reluctant to do any further sanding or buffing with rotary tools due to how thin the existing paint it already is.
Ultimate Compound is SMAT and for use by hand and DA.
Rubbing Compound is DAT and according to Megs hand use only.
Also Ultimate Compound is slightly more abrasive so will have more cut.
Similar Threads
By 9000RPM in forum Auto Detailing 101
Last Post: 02-21-2015, 12:22 AM
Last Post: 02-21-2015, 12:16 AM
By zlman in forum Auto Detailing 101
Last Post: 08-02-2013, 08:28 PM
By Legaspi89 in forum Product Reviews
Last Post: 03-20-2012, 04:35 PM
By WRAPT C5Z06 in forum Auto Detailing 101
Last Post: 12-17-2010, 08:09 AM
Posting Permissions
- You may not post replies
- You may not edit your posts
Forum Rules
S |
M |
T |
W |
T |
F |
S |
31 |
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
| 1 | 2 | 3 | 4 |
Bookmarks
