Thanks Thanks:  0
Likes Likes:  0
Dislikes Dislikes:  0
Results 1 to 5 of 5
  1. #1
    Junior Member
    Join Date
    May 2015
    Posts
    37
    Post Thanks / Like
    Duragloss Environshield Squeaky Clean question
    Very new to detailing, just bought a Porta Cable and did my black 2007 Porsche which had swirl marks with great results using:
    1. wash and dry using DG CCW
    2. clay using Blackfire
    3. DG Swirl Remover (followed Mike Phillips technique with 6 passes)
    4. DG Squeaky Clean
    5. IPA wipe down as the SC left some flakes
    6. Nanoglass coat x 2 24 hours apart
    My question is when applying the Squeaky Clean, can I just apply it with one pass and then buff off after it hazes over or do I need to do the 6 pass "polish"? It's a lot more work but since I'm committed, I'll do it if it improves the prep.
  2. #2
    Super Member
    Join Date
    Mar 2014
    Location
    Newington, CT
    Posts
    261
    Post Thanks / Like
    Re: Duragloss Environshield Squeaky Clean question
    DG SQC is a very good paint cleaner. I would have done it as step 3, i.e. clean the paint before correcting it.
    Do 1 pass. If pad is clean you are done. If pad shows dirt change to a clean pad and do a 2nd pass with SQC to show that all oxidation has been removed.
  3. #3
    Junior Member
    Join Date
    May 2015
    Posts
    37
    Post Thanks / Like
    Thanks for the info. I have 4 more cars to do this summer as they vary from 5 - 10 years old and have never had any paint correction but lots of machine car washes.
  4. #4
    Super Member
    Join Date
    Aug 2010
    Location
    New Jersey
    Posts
    15,150
    Post Thanks / Like
    You did the steps in the right order. The SQ is not doing anything but a prep step for the coating, so you just need to work it in well, if that's 6 passes--I'm not sure what you mean by "Mike Phillips technique with 6 passes".
  5. #5
    Junior Member
    Join Date
    May 2015
    Posts
    37
    Post Thanks / Like
    Quote Originally Posted by Setec Astronomy View Post
Similar Threads
  1. Introducing: Duragloss Squeaky Clean
    By richy in forum Product Reviews
    Last Post: 01-20-2018, 11:24 PM
  2. Replies: 4
    Last Post: 06-14-2015, 09:54 PM
  3. Squeaky Clean + PBL Coating
    By richy in forum Show N' Shine
    Last Post: 04-22-2014, 12:12 PM
  4. The Power of Duragloss Squeaky Clean
    By richy in forum Auto Detailing 101
    Last Post: 06-18-2013, 04:29 PM
  5. Duragloss Squeaky Clean Beta Test - TLC Auto Detail
    By Flannigan in forum Product Reviews
    Last Post: 08-04-2012, 11:36 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
» April 2024
S M T W T F S
31 1 2 3 4 5 6
7 8 9 10 11 12 13
14 15 16 17 18 19 20
21 22 23 24 25 26 27
28 29 30 1234
