Thanks Thanks:  0
Likes Likes:  0
Dislikes Dislikes:  0
Results 1 to 6 of 6
  1. #1
    Super Member
    Join Date
    Mar 2014
    Location
    Orange County, CA
    Posts
    407
    Post Thanks / Like
    Combining Inline softener and deionizer?
    Hey all,
    Wondering if anyone has done this setup - adding the inline softener filter from AGO to the CR Spotless or GG Deionizer systems? In my search I've seen it suggested but never anyone with a review of how it actually goes together.
    I have massively hard water at my house (550-650ppm on avg) and go through resin in my existing deionizer super fast. Since changing the huge bag is majorly expensive (not to mention time consuming) I was wondering if others have done this to get added life out of their DI water and simply replace the easier inline resin?
    Also, if anyone has used the inline filter, does it have to be mounted or could I just strap it to the existing cart with my DI tanks?
    Thanks for any help or experiences with this topic.
  2. #2
    Super Member octane's Avatar
    Join Date
    Apr 2012
    Location
    Ottawa, Canada
    Posts
    398
    Post Thanks / Like
    Re: Combining Inline softener and deionizer?
    do a search online about recharging DI resin, all you need is muriatic acid and lye. I recharged my homemade system multiple times for under 20$
  3. #3
    Super Member
    Join Date
    Aug 2010
    Location
    New Jersey
    Posts
    15,150
    Post Thanks / Like
    Quote Originally Posted by LaFawnduh View Post
    Unfortunately this won't work. The problem with the concept is that a softener is an ion exchange process, so you will exchange your hardness ions for sodium or potassium ions...but the resultant soft water will still be loaded with the same number of ions it had when it was hard. Your deionizer will then remove those ions and be depleted in the same amount of time.
  4. #4
    Super Member swanicyouth's Avatar
    Join Date
    Mar 2011
    Location
    Limerick, PA
    Posts
    9,388
    Post Thanks / Like
    Quote Originally Posted by Setec Astronomy View Post
    This is the right answer...Or sort of....You may get a bit more out of the resin if the water was pre-softened. Mixed bed DI resin works on ion exchange based on polarity of the ion (charge). I'm totally going off the top of my head here, but since Na+ & K+ are monovalent cations, and Ca++ is divalent. - the resin may hold more individual ions of Na+ & K+ (CL) than Ca++.
    So if your water is "salty" or "sodium rich", it may be easier to soften than calcium rich water.
    But, this is all theory. Unless there is a skilled inorganic chemist out there - who knows???
  5. #5
    Super Member
    Join Date
    Aug 2010
    Location
    New Jersey
    Posts
    15,150
    Post Thanks / Like
    I'm sure you're right, I simplified it a little. He'd probably be using NaCl rather than KCl, but remember there is some Mg as well as the Ca in the hard water. IIRC the mixed bed is doing ion exchange in the first resin and removal in the second.
    I don't know, maybe I'm wrong. I remember thinking about doing this with my CR, running my softened water into it, but either I did it and it didn't help, or I decided it wouldn't help so I didn't do it, or someone told me it wouldn't help.
  6. #6
    Super Member
    Join Date
    Mar 2014
    Location
    Orange County, CA
    Posts
    407
    Post Thanks / Like
    Thanks, Gents. Saves me some money on a filter for use on resin or chemical recharge.
Similar Threads
  1. Deionizer AND water softener....overkill?
    By 98LowRanger in forum Auto Detailing 101
    Last Post: 06-10-2019, 09:21 AM
  2. Portable Deionizer maybe?
    By ELGreco in forum Auto Detailing 101
    Last Post: 09-11-2017, 02:46 PM
  3. Who's using a deionizer?
    By DetailKitty in forum Auto Detailing 101
    Last Post: 05-20-2017, 09:09 AM
  4. Anyone use the Clear Inline Hose Filter & Softener from AG?
    By HeavyMetal in forum Auto Detailing Tools and Accessories
    Last Post: 03-15-2011, 10:29 AM
  5. Foam Gun and Deionizer
    By 06CivicSi in forum Auto Detailing Tools and Accessories
    Last Post: 04-07-2009, 12:30 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
» April 2024
S M T W T F S
31 1 2 3 4 5 6
7 8 9 10 11 12 13
14 15 16 17 18 19 20
21 22 23 24 25 26 27
28 29 30 1234
