Dislikes: 0
Junior Member
wolfgang finishing glaze question/ uber
I just did a test on my trunk of my 2003 c320 to see if wg swirl remover and either a ccs white pad or orange would do the job. I had to use the orange pad to get it to work on all the light swirls but did not get out the deeper scratches. I am going to try wg uber compound on a white pad to see if that will get them out. (can't feel scratches with fingernail). Any way should i use my wg finishing glaze with ccs gold pads to top either the swirl remover or uber?, or should i use the white pad? after the glaze i am going to top with klasses sealer and let dry for 12hours then top with 2 coats of wg fuzion. going to be winterizing maybe in october.
Super Member
Re: wolfgang finishing glaze question/ uber
Use the white pad - and take the blue pill.
Super Member
Agree, use Uber with orange pads and finishing glaze with the white. Those are common combo's. As always, a test spot will tell you if you are on right track.
The gold pads would be a waste of time for correction with the DA polisher.
I agree that the WGFG on what sounds like harder paint will probably not do much, but that's what a Test Spot is for
Based on what you have described so far, including some deeper scratches, I would do a Test Spot with Uber/Orange, followed by TSR/White and just for Fun, follow with WGFG on Black and/or White
We are sometimes surprised about what combos work on what paint
Have Fun
Junior Member
ok that works. should i use the gold pads i have to apply the klasse sealant or wg fuzion, or do by hand?
Gold pad would be great for that
Keep the speed at 2-3 on a DA
I usually hit everything I can with the DA and then remove the pad from the DA and hit tight areas like under door handles
Super Member
WGTSR is a totally killer product, with ab-so-tutely no doubt in my "little" mind!
But, as these smart-wise folks suggest, and as we all know, no 2 vehicles are alike! The "proverbial test spot" is what will get you to home base.
Buy buy buy! One NEVER has enough products! LOL
Junior Member
ok cool i might use it for the kassle then since i like to apply wax by hand
Similar Threads
By Pjstockford in forum Auto Detailing 101
Last Post: 07-02-2018, 06:48 AM
By Scubadaddy in forum Wolfgang Car Care
Last Post: 02-28-2014, 09:49 PM
By greg72982 in forum Auto Detailing 101
Last Post: 04-20-2012, 11:25 AM
By HeavyMetal in forum Ask your detailing questions!
Last Post: 06-17-2011, 05:35 PM
By Phinox in forum Product Reviews
Last Post: 08-17-2010, 08:48 PM
Posting Permissions
- You may not post replies
- You may not edit your posts
Forum Rules
S |
M |
T |
W |
T |
F |
S |
31 |
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
| 1 | 2 | 3 | 4 |
Bookmarks
