Dislikes: 0
Old jeep hasn't even been washed in years, need product advice
It's a red 97, and it's not even had a bath in several years. Parked outside, top off 24/7/365. The paint needs work. Some oxidation, marring, etching from droppings and water. clear coat isn't failing though.
What I've done: I did get some shine/definition out of a test portion of the hood. wash/clayed then used progressively stronger meguiars products, including swirl remover and up to meguiars ultimate compound on a yellow lake country pad using a porter cable. The results were ok, good but not great. there's still some imperfections. Results were obtained using 3 rounds with the UC, moving slowly, good pressure each time. As there was still work to do, felt like I might want to step up the cutting.
Question now is where to go from here. Purple pad? Or a product with more cut? Open to recommendations on either.
Or should I just hit it with UC a couple times and be happy with the moderate amount of shine from a nearly 20 year old off road vehicle?
Thanks in advance.
Super Member
Re: Old jeep hasn't even been washed in years, need product advice
2013 Genesis Coupe 3.8 Track Edition
2015 Hyundai Sonata Limited, 2016 Pearl White Nissan Altima SR
2019 Nissan Rogue SL
Originally Posted by custmsprty
Dark and raining at this point, would if I could. But the jeep is low man on the totem pole and doesn't live in the garage.
Originally Posted by Setec Astronomy
I'm not sure what you mean by purple pad--purple foamed wool? Make sure you get the thin ones for your PC. How about a microfiber pad with some M105 or D300?
Yes, that's what I meant.
I've never used 105, still fairly new to this, but willing to give it a shot if that's the way to go.
Super Member
I would say even Ultimate Compound on a Microfiber cutting pad. The MF compound would obviously cut more.
pick up some m105 and the microfiber cutting discs, then try the cutting discs and your uc. if that doesn't work, try the m105 that you just bought!
Super Member
M101 or Menzerna FG400 on a Meguiars Microfiber Cutting Disc will do wonders. Follow it up with some M205, Menzerna SF4000, or even HD Polish on a white or green pad. There are so many product choices out there! You're better off sticking to one or two products that you enjoy working with and perfecting your technique.
Can you share a picture of before and after?
Sounds like a job for a wool pad on a rotary buffer and just get in there and get chopping.
When this old car came in I tried working with just foam cutting pads and Uber Compound with the Flex 3401 and after just a few minutes I whipped out the Flex PE14 with a wool cutting pad and simply got the pain over with....
Somewhere I have the before pictures, (it was filled with swirls and scratches), but the after pictures kind of tell the story too....
Mark's Fast Ferrari with Wolfgang Fuzion
There's not a ton of paint or at least real estate on a Jeep. The key to buffing out Jeeps is taping off anything you don't want to creme over with compound or polish residue.
You are the man Mike...wool pad on a Ferrari...
Similar Threads
By PeteT19640 in forum Ask your detailing questions!
Last Post: 10-29-2020, 11:01 PM
By Joe@NextLevelDetail in forum Product Reviews
Last Post: 02-11-2017, 04:05 PM
By quantim0 in forum Show N' Shine
Last Post: 04-16-2014, 07:20 AM
By jamesalanb in forum Auto Detailing 101
Last Post: 07-25-2013, 04:30 PM
By CASH XRS in forum Porter Cable 7424XP Dual Action Orbital Polisher
Last Post: 03-01-2012, 01:12 PM
Posting Permissions
- You may not post replies
- You may not edit your posts
Forum Rules
S |
M |
T |
W |
T |
F |
S |
31 |
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
| 1 | 2 | 3 | 4 |
Bookmarks
