Thanks Thanks:  0
Likes Likes:  0
Dislikes Dislikes:  0
Results 1 to 5 of 5
  1. #1
    Newbie Member
    Join Date
    Jul 2014
    Posts
    2
    Post Thanks / Like
    Baked on MEG's UC
    I was using Meg's ultimate compound with a 4" rotary. It was getting dark and I thought I removed it all. I wasn't able to look at it late in the next day. Needless to say there was splatter everywherey. And since I live in South FL it is now baked on. How do I get it off without having to compound again? It just won't rub off!
    Plus how do I blackin the door handles and rubber back to black?. The handles are the worst and the black on the running tube brackets. Please help, thank you!
  2. #2
    Super Member RobertJ34's Avatar
    Join Date
    Nov 2013
    Location
    Orlando, FL
    Posts
    345
    Post Thanks / Like
    Re: Baked on MEG's UC
    try washing the car, try using All purpose Cleaner to help remove it. You can spray a diluted APC on it (ex: 1:10 APC:water ratio), let it sit a bit then wash.
    look for a trim coating/trim restorer to bring back the rubber/doorhandles
    Detail exterior trim & metal with Autogeek's large selection of polishes, dressings and tools! mothers, dp, meguiars, powerball, forever black,
  3. #3
    Super Member Desertnate's Avatar
    Join Date
    Aug 2013
    Location
    St Louis metro (Illinois)
    Posts
    5,803
    Post Thanks / Like
    QD spray might be another option as well.
    Drop by to see the latest at The Car Geek Blog
  4. #4
    Newbie Member
    Join Date
    Jul 2014
    Posts
    2
    Post Thanks / Like
    Okay, thank you I'll try APC spray.
    I tried QD before I posted it didn't work
  5. #5
    Super Member FUNX650's Avatar
    Join Date
    Dec 2010
    Location
    Ohio, USA
    Posts
    21,057
    Post Thanks / Like
    "Like dissolves Like"
    •Meguiar's UC contains (per its MSDS):
    -CAS# 64742-88-7...Solvent naphtha (petroleum)
    -CAS# 64742-46-7...Hydrotreated middle distillate (petroleum)
    •Since you do not want to "compound again":
    -Naphtha will suffice in removing the UC's unwanted remnants.
    Dampen a cloth with the Naptha.
    Gently blot the UC-spots with the Naptha impregnated cloth.
    Remove UC residue with another cloth.
    This process may have to be repeated.
    Do not allow the Naptha to dwell too long.
    Be sure to wash the affected areas.
    Then:
    I recommend an application of your choice of LSP.
    Good Luck!!
    "Be wary of the man who urges an action in which he himself incurs no risk."
    ~Joaquin de Setanti
Similar Threads
  1. Baked on plastic
    By Coopers ST in forum Auto Detailing 101
    Last Post: 07-07-2019, 05:11 PM
  2. Sun Baked Leather
    By kshaw in forum Ask your detailing questions!
    Last Post: 06-15-2019, 10:41 AM
  3. Baked on tree sap
    By Theraven in forum Auto Detailing 101
    Last Post: 10-31-2014, 09:54 AM
  4. Baked on Bugs, what to do?
    By WannabeG in forum Auto Detailing 101
    Last Post: 05-14-2011, 10:58 AM
  5. Need help removing baked on PAM!!
    By bobinsofla in forum Ask your detailing questions!
    Last Post: 10-13-2010, 08:57 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
» April 2024
S M T W T F S
31 1 2 3 4 5 6
7 8 9 10 11 12 13
14 15 16 17 18 19 20
21 22 23 24 25 26 27
28 29 30 1234
