Dislikes: 0
Sanding through clear with 2000 grit?
Quick question on this.... I had a chip on a corner of my fender which I dry sanded with 2000 grit to smooth the edges of the clear. I touched it up with paint (dark shadow gray metallic) and clear mixed 50/50. I let it dry and then wet sanded (to feather out the touchup) and buffed. However, you can see a dark spot where it almost looks like I sanded through the clear, but it's shiny like there is still clear.
My question is, how easy is it to go all the way through the clear with 2000 grit? And is it possible that, while wetsanding, the paint/clear mix blended with the OEM finish and makes it appear darker? As I look at it on camera, it actually looks like I may still have a hard edge that needs sanded/buffed a bit more. The paint is also kinda hazy on the tops of the fenders and hood as this was a Texas car. What say you, Autogeek!??!
Thanks!
Dan
Dan
2003 Cobra DSG Coupe - 1 of 851
Super Member
Re: Sanding through clear with 2000 grit?
Add more touch-up paint before you do any more sanding. Looks like you created a little bit of a valley when you sanded out the chip. Touch-up paint shrinks into the lower areas as it dries, so you need to add more to continue to fill the chip/sanding. After a few layers, try wet sanding with 3000 grit to level with the original paint. If it still looks low, then add another layer or 2. Once you get it level and wet sanded where you want it, then polish. Try to focus the sanding on the touch-up area so you don't go through the clear on the OEM paint (other than feathering the edge into the OEM).
2016 Accord EXL V6 w/Navi & Sensing - Black/Ivory
2019 Acura RDX A-Spec - Black/Red; 2019 Acura TLX Base 2.4L - MSM/Black
2008 CRV EX - Black/Black 2003 Accord EX V6 - Black/Tan
OK yea that's kinda what I was thinking that I needed to add a little more clear and then re-feather it. If you look close you can see the original chip kinda in the middle and another layer of clear on it that has not yet been sanded. I think I will smooth that out and then go a light layer over the "darker" area and then feather it out into the fende.r
Dan
It's easy to sand through the clear using #2000. Especially around an edge.
To test if you've sanded through the clear layer, rub some white colored polish on a white cloth to the area in question, if you sanded through the clear the color of the color or base coat will show up on the cloth.
Pretty crazy, I only did maybe 5-6 passes with light pressure.
I noticed paint coming off when I buffed with a towel, but I figured that was because I touched up with paint/clear mixed. I will check it out later tonight. If this is the case, can I apply a thin layer of clear directly and feather it out?
Edit:
To be more clear, you can only really see it at this angle and looking directly down the paint still seems unaffected as the flake looks the same.
Dan
Super Member
Agreed. Especially the part about the edge.
Super Member
Sanding edges can be a deal killer. Bet you won't do that again. Sorry for your loss
Luckily it's only noticeable to my OCD eye. Thanks for all the useful (and not so useful) information guys!
Dan
Super Member
try wet with lube next time
Similar Threads
By Roan65 in forum Wet-Sanding, Cutting & Buffing
Last Post: 04-18-2019, 08:34 PM
By Mike Phillips in forum How to articles
Last Post: 12-19-2017, 05:30 PM
By Mike Phillips in forum Product Reviews by Mike Phillips
Last Post: 06-19-2017, 12:02 PM
By Honda Enthusiast in forum Wet-Sanding, Cutting & Buffing
Last Post: 03-03-2017, 06:45 AM
By zckid in forum Auto Detailing 101
Last Post: 03-07-2012, 08:26 PM
Posting Permissions
- You may not post replies
- You may not edit your posts
Forum Rules
S |
M |
T |
W |
T |
F |
S |
25 | 26 | 27 | 28 | 29 |
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
| 1 | 2 | 3 | 4 | 5 | 6 |
Bookmarks
