Thanks Thanks:  0
Likes Likes:  0
Dislikes Dislikes:  0
Page 1 of 6 123456 LastLast
Results 1 to 10 of 57
  1. #1
    Super Member zmcgovern45's Avatar
    Join Date
    Sep 2012
    Location
    St. Louis, MO
    Posts
    3,443
    Post Thanks / Like
    "Hellaflush" and now "Hellaglossy" - 2013 Scion FRS Corrected and Coated with CQuartz UK
    The owner of this vehicle contacted me late last year because he had noticed that his brand new vehicle was already showing swirls in the paint. We had decided to pursue a one-step correction and then top it with a paint coating to remove the majority of the lighter swirls to really maximize the appearance of the paint, and then top it with a coating to protect the surface and keep it looking nice for a long time.
    The paint on this vehicle was some of the softest I have ever encountered. After spending an hour testing various product & pad combinations, I finally dialed in my process and was able to achieve some pretty drastic improvement for a one-stage correction process. This paint pushed my patience to the limits at times, as even my softest towels would leave some light marring and then I would have to quickly polish that area again. When it was all said and done, the paint looked great. It was an overwhelming bright red that really popped in the sunlight.
    Enjoy the pics!
    Process
    - Tires: Meguiar's D103 (10:1) w/ Tuf Shine Tire Brush
    - Wheels: CG Citrus Wash with various brushes/tools and sheepskin mitt
    - Wash: CG Citrus Wash
    - Decontamination Step 1: IronX
    - Decontamination Step 2: Fine Grade Clay with Nanoskin Glide (10:1) as lube
    - Paint Thickness Readings Taken
    - Taped Off Trim & Emblems Where Needed
    - Correction Process: Menzerna SF4500 on White LC pad via Rupes LHR21ES (5.5" pads) and Rupes LHR75E (3" & 4" pads)
    - Coating Surface Prep Step 1: Diluted IPA (~20% solution)
    - Coating Surface Prep Step 2: Citrus Wash Foam Soak
    - Coating Surface Prep Step 3: Eraser Wipe Down
    - Coating Application: CQuartz UK
    - Coating Cured in Sunlight
    - Coating topped with Reload
    - Tires: CarPro PERL
    Before
    The car arrived fairly clean with just some light dirt and water spots
    There was literally no ground clearance on this car... time to get started with the wash.
    During
    As always, wheels were first. I started by cleaning the barrels of the wheels.
    Next I moved onto the faces of the wheels
    and finally cleaned up the lug nuts and bore
    The vehicle was then degreased, carefully washed, and then blown dry with the Master Blaster
    Once the paint was clean, I was able to inspect the condition of the paint. It was definitely in worse shape than you would hope a vehicle with only 3500 miles would be.
    The next morning I was able to pull the car out into the sun to truly reveal the condition of the paint. There were a lot of swirls covering the entire vehicle. Significantly more than you would expect for a relatively new car.... this should have been my first clue that I was going to be dealing with soft paint.
    After a lot of testing (M205 on white left light marring & even M205 on black left very light marring), I dialed in my process and due to the very soft paint, was able to achieve very good correction with SF4500.
    Hood before polishing
    Hood after polishing
    How about that gloss & depth!
    50/50 shot on the pillar
    50/50 shot on the door
    Retired Professional Detailer
  2. #2
    Join Date
    Sep 2012
    Location
    St. Louis, MO
    Posts
    3,443
    Post Thanks / Like
    Re: "Hellaflush" and now "Hellaglossy" - 2013 Scion FRS Corrected and Coated with CQuartz UK
    It is not often that I work on a vehicle that makes my own look like a giant, but this one certainly did!
    Once polishing was complete, tape was removed before I started prepping the paint for the coating
    The surface was sprayed with a diluted IPA mixture
    Next the car was foamed with a mixture of citrus wash & APC to remove any remaining oils from the surface of the car.
    The car was then blown dry and wiped down with Eraser. Then CQuartz UK was applied to the paint.
    Once the coating had been applied, I pulled the vehicle out to check for high spots & streaks
    The car was then left to cure in the sunlight for several hours... the paint looked great!!
    After
    The shine was a mile deep!
    The red really popped, and the gloss was incredible
    Ready for pickup
    The paint looked dripping wet
    Deep & red!
    Wheels cleaned up nicely
    low enough?
    As Always, Thanks for looking!
  3. #3
    Super Member EVOlved's Avatar
    Join Date
    Oct 2013
    Location
    Queens, NY
    Posts
    1,128
    Post Thanks / Like
    Looks fantastic!! Crazy how soft that paint was. The stance is a little too aggressive for me but looks great either way.
  4. #4
    Super Member JSou's Avatar
    Join Date
    Dec 2012
    Location
    Northern Virginia
    Posts
    1,635
    Post Thanks / Like
    HARD!
    Looks great Zach. You rocked this one. I love me some FRS/BRZ.
  5. #5
    Super Member statusdetailing's Avatar
    Join Date
    May 2012
    Location
    Springfield, Mo
    Posts
    1,325
    Post Thanks / Like
    That shine really is a mile deep. Thanks for the info on the paint softness. Will remember to start with SF4500 and go from there, when I come across one. It finished out very nicely.
    How do you like the gilmour foam gun?
    Jeremy Wayne
  6. #6
    Super Member 281's Avatar
    Join Date
    May 2013
    Location
    The City
    Posts
    2,440
    Post Thanks / Like
    Wow that FRS is poppin! Thanks for sharing...
  7. #7
    Super Member parttimer's Avatar
    Join Date
    Aug 2013
    Posts
    1,564
    Post Thanks / Like
    Looks great, but damn that is some major camber on those back tires!
  8. #8
    Regular Member David at LC Pads's Avatar
    Join Date
    Oct 2013
    Posts
    198
    Post Thanks / Like
    Looking Good!
  9. #9
    Super Member BrianMcLeod's Avatar
    Join Date
    May 2013
    Posts
    812
    Post Thanks / Like
    Nice work!!
    Like my page on facebook ill like back - https://www.facebook.com/pages/Brian...668?fref=photo
  10. #10
    Super Member
    Join Date
    Feb 2011
    Location
    Minot, ND
    Posts
    12,365
    Post Thanks / Like
    Beautiful work as always Zach! That gloss is 10 miles deep!
    Car looks great as well. Like what the owner did with it but the front needs more work. IE, more stance. Lol
Similar Threads
  1. Review of Son1c's "Capped in America" and "Prototype Black Wax"
    By hardrock2401 in forum Product Reviews
    Last Post: 09-20-2015, 07:11 PM
  2. "Hellaflush" / Slammed Cars Banned in Quebec
    By swanicyouth in forum Off-Topic
    Last Post: 08-06-2014, 09:57 AM
  3. Replies: 9
    Last Post: 12-21-2013, 11:16 AM
  4. Replies: 20
    Last Post: 10-08-2012, 12:59 PM
  5. CQuartz"New Improved" and also CQuartz"Leather"
    By IID in forum New Car Care Products
    Last Post: 07-11-2011, 09:35 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
» April 2024
S M T W T F S
31 1 2 3 4 5 6
7 8 9 10 11 12 13
14 15 16 17 18 19 20
21 22 23 24 25 26 27
28 29 30 1234
