Dislikes: 0
How do you remove grease marks from paint?
Maybe because I need a paint job anyway, every single mechanic, private or at a shop, ends up getting my car's paint dirty with grease marks. I know I need a paint job anyway, but most of my current paint job actually looks pretty good, and I try to keep it that way.
Whats the best way of removing grease marks from your cars paint? Some of them are from up to 9 months ago.
Im thinking dawn dish soap or wax and grease remover. Then I know I have to reapply some wax. Should I overlap the areas' edges when waxing? Beause I dont see how I can control exactly what will be removed with the soap, especially since it will be dripping down. Plus I last waxed the car about 5 months ago, so it will look weird to have certain areas freshly waxed and certain areas not.
Also if I use soap.. Can I just use a regular sponge? I dont want to buy another nice car wash sponge just to get it greasy right away.
Also, for the future, is there any way to remove the grease marks when theyre kinda fresh? Hopefully without having to wax it again. Usually I get someone I know to do the work, and I could try to wipe it off within an hour or so of it getting dirty. With a shop though, the grease has plenty of days to set in. I like to do all my work myself, but some things I just need a shop to do.
Junior Member
Re: How do you remove grease marks from paint?
Your plan of attack seems similar to what I would do assuming you've already tried a less aggressive soap. I wouldn't use a sponge I'd think you'd be better off sacrificing one microfiber towel just for the grease spots, been my experience that most sponges are pretty hard on paint. And if you haven't waxed the car in five months why not just make a day or half day of it and do the rest of the car as well? As far as removing the grease if hasn't been sitting for days and the car has a fresh coat of wax on it quick detailer or even spray wax would probably do the trick.
Super Member
Just use APC and a MF towel that's all you really need and if you want to wash it off dawn will remove the grease for you.
Super Member
+1 APC should do it.
And I'd be pissed at the mechanics for getting my car dirty! I understand it happens, but damn! At least try!
2022 Jeep Gladiator Rubicon • 2021 Ford Ranger Lariat •2016 Alfa Romeo 4C Spider • 2006 Buell Lightning-Bolt • 2004 Jeep Wrangler Rubicon
Super Member
Detail your car before having it serviced. If your car looks like you don't care, they won't either
The quick detailer and APC did not work, and that was on fresh stains from a few hours ago. Yes I am kinda irritated it always happens.. I wash it every week, and did a real good clay, polish, and wax 5 months ago. I think it still looks pretty good. Its just a lot of minor imperfections in the paint which add up and make people think its not worth respecting. The inside is kept spotless. I think the mechanics try, but they just get a little lazy because of all the cars they work on.
What do you guys think about wet sanding it, maybe with 1500 then 2000? Then buffing, then waxing. That wont remove the clear coat will it? Or are you supposed to remove wax and grease before sanding?
Super Member
Try Naptha (zippo fluid) b4 going to sanding. If Naptha wont get it, then move up to Acetone, if that wont remove it, then you have issues. You will have to rewax any area thoes chemicals touch. Worst case try laquer thinner. Any 3 of the above should melt the grease right off.
Super Member
Are you being serious?!?!?
Of course you should remove the wax and grease before sanding
Regular Member
Amen....
Similar Threads
By Jershinator in forum Ask your detailing questions!
Last Post: 04-20-2019, 12:28 AM
By getslideways in forum Ask your detailing questions!
Last Post: 07-01-2017, 11:27 PM
By adudley88 in forum Ask your detailing questions!
Last Post: 08-14-2010, 05:33 AM
By YankeeFan in forum Auto Detailing 101
Last Post: 09-24-2009, 12:41 PM
By pnut in forum Ask your detailing questions!
Last Post: 09-23-2009, 07:32 AM
Posting Permissions
- You may not post replies
- You may not edit your posts
Forum Rules
S |
M |
T |
W |
T |
F |
S |
25 | 26 | 27 | 28 | 29 |
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
| 1 | 2 | 3 | 4 | 5 | 6 |
Bookmarks
