Thanks Thanks:  0
Likes Likes:  0
Dislikes Dislikes:  0
Page 1 of 3 123 LastLast
Results 1 to 10 of 26
Thread: Pressure Washer
  1. #1
    Junior Member RoacheC's Avatar
    Join Date
    Aug 2012
    Location
    Westfield, MA
    Posts
    32
    Post Thanks / Like
    Question Pressure Washer
    I see the most common used way to wash a car is with a pressure washer, now here is the question is a pressure washer (PW) just that or is a special PW really needed, I can already assume having the right pressure setting is a must, which leads to my 2nd question what is the best pressure number? I dont wanna blow the paint off my car. lol
  2. #2
    Super Member craz0boy's Avatar
    Join Date
    Apr 2012
    Location
    Texas
    Posts
    283
    Post Thanks / Like
    You really don't need anything higher than 2000psi. I have your standard 1700psi electric pressure washer I use on every detail I do. Works great gets the job done.
  3. #3
    Super Member swanicyouth's Avatar
    Join Date
    Mar 2011
    Location
    Limerick, PA
    Posts
    9,388
    Post Thanks / Like
    I don't think you really need 1700psi. Unless your working on some filthy cars, then it may come in handy. My psi washer is only 1450 psi and works great. Also, a lot depends on the tip or wand you use. A 1450 psi with a standard wand tip is fine. Put on a "dirt buster" tip or attachment, and the spray is so strong it will almost take your skin off if you put your hand in front of it.
  4. #4
    Join Date
    Aug 2012
    Location
    Westfield, MA
    Posts
    32
    Post Thanks / Like
    Re: Pressure Washer
    So it sounds to me going to Home Depot getting something half decent will do the trick long as I keep the pressure setting right.
  5. #5
    Regular Member rdf's Avatar
    Join Date
    Mar 2006
    Posts
    115
    Post Thanks / Like
    Re: Pressure Washer
    The ones in my price range don't have adjustable pressure settings. You modulate the force applied to the surface (paint, deck, sidewalk, etc) by increasing or decreasing the distance between the wand tip and the surface.
  6. #6
    Super Member jwellsii's Avatar
    Join Date
    Sep 2009
    Location
    Jacksonville, FL.
    Posts
    449
    Post Thanks / Like
    Re: Pressure Washer
    Go to your local professional pressure washing supply store (not home center) and get a fan tip, you will not hurt the paint under any pressure.
    Dirt-B-Gone Mobile Detailing
    www.HandWashAndWax.com
    facebook.com/DBGMobileDetailing John Wells
  7. #7
    Super Member master detailer's Avatar
    Join Date
    Nov 2010
    Location
    cape coral fl
    Posts
    548
    Post Thanks / Like
    Re: Pressure Washer
    on the good ones you can set it at any pressure you like and change tips also. For my self I dont like the elc ones but I do lots of rvs and boats and need power a lot of the time .My honda runs and runs all day long if you get a gas one get a cat pump there the best pump out there easy to put new o rings in also ps get one that has a blow off on it .will let water pass by the pump and not blow the seals. lets you have it runing and not pull the triger to let pressure off the pump.
  8. #8
    Super Member tuscarora dave's Avatar
    Join Date
    Aug 2009
    Location
    Etters PA
    Posts
    5,403
    Post Thanks / Like
    Re: Pressure Washer
    Quote Originally Posted by rdf View Post
    I lucked into a pressure washer with a Honda engine and a General Pump belt driven cast iron/brass pump for $150, this thing will blast the paint right off of a car if you either squeeze the wand trigger while the wand is pointed directly at the paint, or get the tips too close to the paint. Already been to the body shop out of pocket on this one.
    The $400 out of pocket paint shop bill was a lesson in keeping the tip a certain distance from the paint that I won't forget any time soon. On gel coat this high pressure unit comes in handy. I can attach the 0 degree tip to the wand and from the ground, blast the bug splatter right off of the gel coat toppers on some of the buses that I clean on a regular basis. That 0 degree tip can strip the paint right off of certain restoration projects that I get involved in. Can surely be a liability but is super useful to have around the shop.
  9. #9
    Super Member wangotango's Avatar
    Join Date
    May 2012
    Location
    pacific n'west
    Posts
    250
    Post Thanks / Like
    Re: Pressure Washer
    Is there not a pressure regulator on your gas driven unit?
    On the pump or adjustable bypass?
  10. #10
    Regular Member
    Join Date
    May 2012
    Posts
    130
    Post Thanks / Like
    Re: Pressure Washer
    Some have regulators. But here is the truth. I have a greenworks 1700 psi. Comes with the gas style quick disconnect wand and not the cheap AIO wands. I use a 25 degree tip on mine. That doesnt mean 1700 psi is coming out. In fact I can put my hand just 2 feet in front of it and it doesnt hurt. So you can even use a 3000psi pressure washer as long as you are at least 2-3 ft from the car. A pressure washer in the 1500-1700 range is recommend for power, without to much power. The only way your going to rip paint off is if you put on the 0 degree fitting which is a straight stream, and then put it point blank at the paint, or if you have a major chip and point it at that.
    Otherwise the hype about being able to do damage is just people talking who dont own pressure washers.
    The only reason I use a pressure washer is to get the dirt out of the seems and to really make sure that all the damage causing dirt is off the car before I touch it with a mitt. I also like to do a foam prewash that helps remove dirt and oils before actually washing the car with a mitt.
Similar Threads
  1. Loss of pressure with my new pressure washer hose
    By CaveRacing in forum Auto Detailing Tools and Accessories
    Last Post: 04-27-2018, 08:02 AM
  2. Replies: 12
    Last Post: 12-13-2017, 08:25 AM
  3. Homemade undercarriage pvc washer for the non pressure washer.
    By ndsports in forum Auto and Garage Accessories
    Last Post: 02-04-2017, 03:09 PM
  4. Pressure washer
    By BrianMcLeod in forum Auto Detailing 101
    Last Post: 11-10-2013, 01:51 AM
  5. Replies: 6
    Last Post: 10-28-2011, 03:11 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
» April 2024
S M T W T F S
31 1 2 3 4 5 6
7 8 9 10 11 12 13
14 15 16 17 18 19 20
21 22 23 24 25 26 27
28 29 30 1234
