Dislikes: 0
Help with fine scratches on windshield
I own a 2011 Hyundai Equus with about 5000 miles on the odometer. In an attempt to remove a few water spots I used Glass Science Glass Scrub cream cleanser and a dish washing sponge that is a little abrasive on one side (typically used when cleaning teflon pans). I washed the front windshield, applied the compound and used the slightly abrasive side to attempt to remove the water spots. After rinsing and towel drying, I noticed very fine scratches throughout the windshield. These marks are noticeable primarily when driving directly into the sun, they are otherwise undetectable. I am, needlessly to say, very irritated with these glass marks. I would appreciate any advice as to how to remove these very fine shallow scratches without the risk of optical distortion using rotary polishers?
Super Member
Re: Help with fine scratches on windshield
Do you have a polisher at all? It will be very hard to remove scratches without a rotary polisher. But if they are extremely light you might be able to with a DA polisher and some patience. I would use CarPro Ceriglass Kit, glass polish, water spot remover with some of these Glass Polishing Pads, glass leveling discs, abraded discs, auto glass polish Next time you have any water spots you can use the hand applicators that come in the Ceriglass kit to remove them You won't really be able to remove any below surface defects by hand but it'll work wonders on water spots. Hope that helps!
Rule 62: Don't take yourself to d*mn seriously
Cincinnati, OH
Shawn
Super Member
I made that same mistake on my old car.
I was removing shoe polish someone used to write on my windows. I couldnt figure out how to remove it, so I used one of those sponges with the abrasive green side. It took it off, but left scratches everywhere.
Thank you for your helpful response. I do not have a rotary polisher. My reluctance to purchasing one is the fear of optical distortion. I do believe the scratches are very fine and agree with you that a rotary polisher may be the solution. Given the outcome of certain past projects (mainly due to impatience), my wife won’t let me handle a rotary system on an expensive car. I will, however, take your advice and try the polish kit with the glass leveling discs. Thanks again.
Super Member
I believe the poster recommended the leveling discs if you had a DA polisher. I'm not sure how those would do by hand. Just wanted to make sure you understood.
Drew
2003 Midnight Black Pearl WRX (Cobb AP stg 2) - Daily
1993 Vintage Red RX-7 Twin Turbo (stock, 18,500 miles) - Sunday
~Drew
Drew,
Thank you for pointing that out. I did misread the previous post.
Super Member
Drew,
No problem. I know Ceriglass has a kit do do it by hand but I'm not sure if it would get out your scratches or not. I used Ceriglass with a DA to remove waterspots on windows.
Drew
~Drew
I will purchase a polisher. Ideally, I would like a single system for both the glass and the paint. I am leaning towards a DA polisher.
Super Member
A DA is great for beginners. Porter Cable, Griots, and Meguiars all make great DA polishers. Ceriglass is a polish that is specifically geared towards glass though. It has an ingredient that cuts glass. Most people have better luck on glass with rotaries but I think I heard that with enough patience you can correct glass with a DA. There are many different polishes for paint. I have used paint polishes on my glass to get off water spots as well (Not sure if a paint polish would take out scratches out of glass though, probably not). There is a lot of info around here so definitely read up before you purchase.
~Drew
Thanks Drew. There goes the weekend. I will research some more.
Similar Threads
By Darkoverlift in forum Auto Detailing 101
Last Post: 01-22-2018, 08:15 PM
By luke41 in forum Ask your detailing questions!
Last Post: 09-04-2013, 02:25 PM
By psa6 in forum Ask your detailing questions!
Last Post: 04-20-2012, 10:26 PM
By Chevy-SS in forum Ask your detailing questions!
Last Post: 01-25-2012, 02:00 PM
By Forced in forum Auto Detailing 101
Last Post: 02-04-2009, 12:59 PM
Posting Permissions
- You may not post replies
- You may not edit your posts
Forum Rules
S |
M |
T |
W |
T |
F |
S |
31 |
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
| 1 | 2 | 3 | 4 |
Bookmarks
