Dislikes: 0
Concerns about multiple colored gelcoats
My dad has a 2006 1900 Regal bowrider I plan on detailing. He has some light oxidation on the back corners near the transom.
My main concern is that the boat is black with a red boot stripe. What do I need to worry about as far as color transfer when using the rotary with polish/compound on gelcoat? Is it normal with gelcoat to get color transfer to the pads?
Thank you in advance.
Super Member
You shouldn't be seeing any color on your pads if it IS gel coat.
David 2000 Ford F-350 DRW CCLB BLACK/GOLD
Wish list:
Everything Mike has in his garage for detailing
So I take it that means I don't need to tape off the different color black and red gelcoat colors where they meet either?
Super Member
If it is gel coat( which every boat should be) then no need to tape the different colors.
Wish list:
Re: Concerns about multiple colored gelcoats
If it's a gel-coat finish then you will see color or pigment come off when you cut the oxidation off using a compound. This pigment won't hurt anything and is normal.
Be prepared to clean your pad often, if you don't have a Spur then get one. Buffing out oxidized gel-coat finishes is where it's real handy to have a pad washer, then you simply clean your pad in the pad washer and the spur the pad to fluff and separate the fibers and get back to work.
If for some reason the boat has a clear coat, (some custom performance boats do), then you won't see color-transfer and if you do that means you made a whoops!
After cutting off the oxidation using a wool pad you'll want to come back and re-buff the gel-coat using a foam pad and if you want a swirl free finish it's easiest to do the last machine step using any DA Polisher so as to change the action of the tool.
Be sure to shares some before and after pictures...
Thanks Mike that is what I was concerned about. Thank you for clearing that up for me.
Had oxidation on the back corners near the swim platform, and halfway up the left hull from where it used to be drystacked.
I started today with the Porter Cable and Megs #50 One Step Cleaner Wax on LC Green CCS Pad. After applying, letting dry to a haze, and removing I was unsatisfied with the results. Still didn't have very much clarity, or reflection.
Decided to just suck it up and go three step:
1) Porter Cable with Megs #49 Heavy Oxidation Remover by LC Purple Foam
2) Porter Cable with Megs #45 High Gloss Polish by LC Green Polishing Pad
3) Porter Cable with Megs #56 Pure was by LC Blue Finess Pad
I will say I was very happy with how all of the Meguiars Products were easy to apply, and buff off afterwards. Worked the Oxidation Remover, and Polish until the product started to dissappear and it buffed right off. Applied the wax evenly, let it dry to a haze, and came right off.
I added before and after pictures below. The after picture is after correction, but before adding the wax. It added significantly more luster, and depth. Will add more later.
Super Member
I learn something everyday, always thought gel coat was a type of clear coat, to the OP sorry for the misinformation on my first post.
Wish list:
Rudy...
NICE turn around!
Bill
Yep... oxidized gel-coat takes a little work to remove and revitalize.
[/quote]
I will say I was very happy with how all of the Meguiars Products were easy to apply, and buff off afterwards. Worked the Oxidation Remover, and Polish until the product started to disappear and it buffed right off. Applied the wax evenly, let it dry to a haze, and came right off.
That's a good, simple system that will work on most boats...
Nice work!
Here's your pictures inserted instead of attached, I uploaded them to your gallery...
Before and After
Thank you for the words of encouragement.
Next I'm tackling the white gelcoat above the rubrail which is oxidized the worst. How does this combination sound?
Meg's #91 heavy oxidation remover via purple foam wool(pc or rotary not sure yet)
Meg's #45 high gloss polish via green polishing pad(pc)
Mega # 56 by hand(lots of curved sections)
I have some 4 inch pads which should help.
My concerns are that I might need to step up to a rotary. I just got the makita 9227C in the mail.
Do you think gelcoat is tough enough to learn on with purple foam pads or should I just step up to the wool pads it comes with?
With wool pads on a rotary with megs#91 should I be able to finish well following with the megs#45 on the PC?(afraid I might end up with some holograms)
Similar Threads
By MshawnBauer in forum Boat & Marine Craft Detailing
Last Post: 07-16-2017, 10:49 PM
By Crazy Amos in forum Auto Detailing 101
Last Post: 01-28-2011, 08:36 PM
By msquared100 in forum Auto Detailing 101
Last Post: 10-28-2008, 08:14 PM
By Ohio Detailing in forum Auto Detailing 101
Last Post: 05-04-2008, 08:44 AM
Posting Permissions
- You may not post replies
- You may not edit your posts
Forum Rules
S |
M |
T |
W |
T |
F |
S |
31 |
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
| 1 | 2 | 3 | 4 |
Bookmarks
