Thanks Thanks:  0
Likes Likes:  0
Dislikes Dislikes:  0
Page 1 of 3 123 LastLast
Results 1 to 10 of 23
  1. #1
    Regular Member
    Join Date
    Dec 2011
    Location
    Adelaide, Australia
    Posts
    165
    Post Thanks / Like
    Chemical etching on interior plastic. How to remove?
    It looks as though I have some chemical stains. I believe they may be caused by an air freshener. How do I clean this up to restore back to its original condition?
    Attached Thumbnails Attached Thumbnails Chemical etching on interior plastic. How to remove?-gear-jpg
  2. #2
    Super Member tuscarora dave's Avatar
    Join Date
    Aug 2009
    Location
    Etters PA
    Posts
    5,403
    Post Thanks / Like
    Re: Chemical etching on interior plastic. How to remove?
    If they are just stains they should polish off rather easy using some Meguiar's Plast-X. I'd suggest applying some Plast-X or some finishing polish to a cotton terry towel and rubbing that area. It may take some elbow grease to get them out but if they are not deep etchings they should rub out. If they are deeper etchings (hard to tell by looking at the photo) you may need to use something more aggressive such as Meguiar's Ultimate Compound on a cotton terry towel and then finish with your lighter polish to gloss it back up.
    Have you tried any sort of polish yet?
  3. #3
    Regular Member
    Join Date
    Dec 2011
    Location
    Adelaide, Australia
    Posts
    165
    Post Thanks / Like
    The stains do not look that deep. I had considered trying some Dodo Juice Prime lime lite but wanted to make sure I was considering the right type of products. I might give that a try and if no joy try some Plast-X
  4. #4
    Super Member
    Join Date
    Aug 2010
    Location
    New Jersey
    Posts
    15,159
    Post Thanks / Like
    That almost looks like it's just some gunk on the surface. Have you tried some water or diluted APC?
  5. #5
    Regular Member
    Join Date
    Dec 2011
    Location
    Adelaide, Australia
    Posts
    165
    Post Thanks / Like
    Tried Megs APC @ 10:1. I have some DJ Clearly Menthol I could try. Other then that I have some Optimum Power Cleaner coming this week or use existing polished. If DJ CM doesn't move it, I doubt OPC would
  6. #6
    Super Member Nappers's Avatar
    Join Date
    Jun 2009
    Location
    Yreka, CA
    Posts
    531
    Post Thanks / Like
    I agree with Dave, some PlastX on there.
    If it were me, I would put some down the size of a pea, use your finger to spread and work the product seen as the plastic surface isn't all that big. Or try an applicator pad. The etching doesn't look that deep.....
    I've had great results with the M105/M205 twins on plastic if you have it.
    Aaron's the name!
    Live long and prosper Leonard Nimoy
  7. #7
    Regular Member
    Join Date
    Dec 2011
    Location
    Adelaide, Australia
    Posts
    165
    Post Thanks / Like
    Just DJ CM, LPL and LP in that order. It didn't appear to do anything at all. I'm going to have a more detailed look at it tomorrow. The more it didn't budge the more I believe it may not be surface stains. Possibly could be stains on the underside of the plastic. So pulling off the gearstick surround might be the next step.
  8. #8
    Regular Member
    Join Date
    Dec 2011
    Location
    Adelaide, Australia
    Posts
    165
    Post Thanks / Like
    Quote Originally Posted by Nappers View Post
    It doesn't look deep at all. Thats why I'm surprised it didn't budge it and beginning to expect maybe its on the underside. Its night time here so going to wait till daylight to inspect further
  9. #9
    Join Date
    Jun 2009
    Location
    Yreka, CA
    Posts
    531
    Post Thanks / Like
    Anyway to pop that off without breaking tabs to further inspect?
    Picture wise, looks like a protectant that got on there and dried.....
    Keep us posted.
    Aaron's the name!
  10. #10
    Regular Member
    Join Date
    Dec 2011
    Location
    Adelaide, Australia
    Posts
    165
    Post Thanks / Like
    Upon inspection it appeared that some of the spotting did come off last night. Which is good news because if it was on the underside of the plastic the whole shifter needs to come out.
    So went and bought some PlastX and it removed a lot of the spotting but there is still some there I'm struggling to budge. Should I try something stronger as don't feel PlastX is going to get the remaining off?
    Here's an updated pic
    Attached Thumbnails Attached Thumbnails Chemical etching on interior plastic. How to remove?-img_0566-jpg
Similar Threads
  1. Ford Fusion interior plastic etching?
    By onsite in forum Tricks, Tips and Techniques
    Last Post: 06-28-2015, 05:58 PM
  2. Tips on how to remove chalkiness from interior plastic
    By pointillistic_practitioner in forum Auto Detailing 101
    Last Post: 05-22-2013, 04:25 AM
  3. Cloth to Remove Interior Dust Daily / Cleaning Clear Plastic?
    By TripleB in forum Auto Detailing 101
    Last Post: 04-24-2013, 06:53 AM
  4. Remove scratches on interior vinyl/plastic?
    By DEXTERITY in forum Auto Detailing 101
    Last Post: 07-23-2012, 04:19 PM
  5. How do you remove scratches in plastic interior trim?
    By offdutyFF in forum Auto Detailing 101
    Last Post: 11-15-2010, 02:39 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
» April 2024
S M T W T F S
31 1 2 3 4 5 6
7 8 9 10 11 12 13
14 15 16 17 18 19 20
21 22 23 24 25 26 27
28 29 30 1234
